Results 1 to 18 of 18
    Junior Member Two Rings
    Jun 30 2007
    Greenville
    Option codes database/list
    After failing to find any code list here or AW I turned to google. The first hit was a generator that no longer worked, but an audi-forums poster had made an .xls back in 2006. I figured it couldn't hurt to host and share the database in case anyone else had trouble looking them up. These are mine.
    http://www.elusivity.com/Option_Code...di_Numbers.xls
    E0A No Special Edition
    1KD Disc Brakes, Rear
    3FE Electric Slide/Tilt Sunroof With Sun Screen/Sunblind
    F0A No Special Purpose Vehicle, Standard Equipment
    T7Z Components For Base Engine, Unit 078.8
    2ZQ Leather Trimmed Multi-Function Steering Wheel For Airbag System
    7Q0 Without Navigation Device
    3PN Electric Seat Adjustment For Both Front Seats With Memory System
    1SA Without Additional Engine Guard
    J1R Battery 420 A (82 Ah)
    0L3 Mechanical Throttle Actuation Plus Manual Accelerator Actuation
    4NX Right Comfort And Left Standard Front Seat, Without Trays
    4HS Heated Rear Window With Rear Wiper
    VV6 Front Axle With Modified Tread
    4UB Airbag For Nar
    1LX Disc Brakes, Front
    8GL Alternator 120A
    8JD Headlight With Gas Discharge Lamp For Driving On The Right (Us Design)
    8Q2 Automatic Headlight-Range Adjustment Static
    7K0 Without Tire Pressure Warning Light
    4KC Side And Rear Windows Tinted
    6XM Outer Rear View Mirrors: Powered, Heatedautomatically Dimming, With Memory Function
    5ME Vavona Wood Insert "Amber", High-Gloss
    0G7 Tiptronic
    U1D Instrument Insert W/ Mph Speedo, Clock, Tachometer, Trip Odometer And Additionalinstruments (Voltage, Oil Temperature)
    9G2 Preparation For Roof Attachments (Fixingparts)
    4X3 Side Airbag Front With Curtain Airbag
    3Y5 Electrically Operated Roll-Up Sun Screenfor Rear Window And Mechanically Operated For Side Windows
    Q1D Sports Front Seats
    1AT Electronic Stabilization Program (Esp)
    7X0 Without Park Distance Control
    0YQ Weight Category Rear Axle Weight Range 14
    X9A National Sales Program Usa
    8Z6 Engine Cooling System, Type 2
    2K5 Reinforced Bumpers
    4K2 Radio Remote Controlled Central Locking Operated From Inside And Separate Trunk Release
    1BE Sports Suspension/Shock Absorption
    0JL Weight Category Front Axle Weight Range 11
    1N3 Speed-Related Variable Steering Assist (Servotronic)
    MH0 6-Cyl. Gasoline Engine 2.7 L/187 Kw 30V Base Engine Is T7Z
    6R0 Selector Lever Cover
    5D2 Carrier Frequency 315 Mhz
    4GP Windshield Tinted With Sun Band And Viewing Window For Vehicle Identification Number
    credit to volcanoblack for the xls.
    Sep 20 2006
    Burnaby, BC, Canada
    Re: Option codes database/list
    thats pretty sweet, where do u find these codes on ur car? do u decypher the VIN or what?
    Jun 30 2007
    Greenville
    Not sure about all models/years but mine was on a sticker in the spare wheel compartment.
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Hey Grandmast
    Here's mine... http://PRSearch.PlanetVAG.com
    The sticker is in the spare tyre well or in the owner's manual.
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Jun 30 2007
    Greenville
    ^bookmarked :)
    Sep 20 2006
    Burnaby, BC, Canada
    w00t did mine at work today... can u tell i was bored?
    PRCode: 0G7 = Tiptronic
    PRCode: 0JM = weight category front axle weight range 12
    PRCode: 0L2 = electric throttle actuation
    PRCode: 0YR = weight category rear axle weight range 15
    PRCode: 1AT = electronic stabilization program (ESP)
    PRCode: 1BE = sports suspension/shock absorption
    PRCode: 1KE = disc brakes, rear
    PRCode: 1LX = disc brakes, front
    PRCode: 1N3 = speed-related variable steering assist (Servotronic)
    PRCode: 1SA = without additional engine guard
    PRCode: 2K8 = reinforced bumpers
    PRCode: 2ZM = leather trimmed multi-function steering wheel
    PRCode: 3FE = electric slide/tilt sunroof with sun screen/sunblind
    PRCode: 3HA = without leather parts scope
    PRCode: 3NQ = rear seat bench unsplit, backrest split folding
    PRCode: 3PN = electric seat adjustment for both front seats with memory system
    PRCode: 3Y5 = electrically operated roll-up sun screenfor rear window and mechanically operated for side windows
    PRCode: 4GP = windshield tinted with sun band and viewing window for vehicle identification number
    PRCode: 4K2 = radio remote controlled central locking operated from inside and separate trunk release
    PRCode: 4KC = side and rear windows tinted
    PRCode: 4UB = airbag for NAR
    PRCode: 4X4 = side airbag, front and rear with curtain airbag
    PRCode: 5D2 = carrier frequency 315 MHz
    PRCode: 5MZ = decorative burr walnut inserts, umbra high-gloss
    PRCode: 6R0 = selector lever cover
    PRCode: 6XM = outer rear view mirrors: powered, heatedautomatically dimming, with memory function
    PRCode: 7K0 = without tire pressure warning light
    PRCode: 7Q9 = navigation system
    PRCode: 7X1 = ultrasonic park distance control
    PRCode: 8GT = compact alternator 90 - 150A
    PRCode: 8JD = headlight with gas discharge lamp for driving on the right (US design)
    PRCode: 8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving)
    PRCode: 8Z5 = engine cooling system, type 1
    PRCode: 9Q2 = multi-function indicator/on-board computer with check control
    PRCode: C9M = alloy wheels 8J x 17 offset 35
    PRCode: D0F = 8-cylinder gasoline engine 4.2 L/220 kW V8 Motronic base engine is T7S
    PRCode: E0A = no special edition
    PRCode: F0A = no special purpose vehicle, standard equipment
    PRCode: J1G = battery 450 A (92 Ah)
    PRCode: Q1D = sports front seats
    PRCode: T7S = components for base engine, unit 077.2 (aluminum)
    PRCode: U1C = instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.)
    PRCode: X9B = national sales program Canada
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    i wish that in depth vin generator still worked
    theres some crappy ones out but there was one in particular that was so detailed... wish we still had it =(
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 20 2006
    Burnaby, BC, Canada
    i found a couple on google, the vin doesn't tell you much anyways... try this one
    http://www.motoverse.com/tools/vin/audi.asp
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I find it easiest to open my eyes and see what options my car came with...
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Three Rings ccomengee86's Avatar
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    Active Member Two Rings Moxi's Avatar
    Jan 26 2014
    Boise, ID
    Quote Originally Posted by ccomengee86 View Post
    Best damned list I have seen to date.
    Silver 2006 A4 Quattro 2.0T FSI (Sold)
    Silver 2010 A4 Premium + 2.0T FSI
    Aug 03 2015
    Casper Wyo
    Does anyone know how to get this info without a sticker?
    I took my 00 a6 into the shop for an alignment today and they said they cannot do it without the suspension codes.
    My sticker exists in the spare tire compartment but is completely brushed off. No sticker in the manual anywhere.
    Sep 16 2010
    Central Wash
    Find a different shop That's the pretty close to the biggest pile of shit excuse I've heard ever.
    FAKE NEWS!!
    Junior Member One Ring DirkOz's Avatar
    Dec 18 2016
    2000 A4 B5 1.8T Quattro Sedan, 1999 A3 1.8T 2 Door
    Canberra/ACT
    Decode your Options here:-
    [Works for my 1999 A4 B5 1.8T Quattro]
    http://igorweb.org/equidec.aspx
    Find your Option Codes inside the Service Book or inside the spare wheel well.
    Dealers should be able provide you with an Options List list based on your VIN.
    Useful information for all, especially when buying or selling.
    Sent from my ASUS_Z00AD using Tapatalk
    Mar 14 2008
    Natick, MA
    Quote Originally Posted by Moxi View Post
    Thanks for the kind words!
    I use that list for the search page I have at http://PRSearch.PlanetVAG.com ...just an FYI..
    Cheers
    Massboykie
    Jul 31 2014
    '05 3.0 A4 Black
    Detroit
    What code is the backup camera?
    Sep 16 2010
    Central Wash
    Quote Originally Posted by 10spd View Post
    OEM backup camera on a C5?
    mmmmmmmmkay. Next Wednesday is April fools.
    Senior Member Three Rings Grainreaper's Avatar
    Nov 19 2016
    Lake in the Hills, Illinois
    10spd, this is the most complete list I’ve ever seen, poke around and see what you can turn up! https://www.bezwypadkowy.net/media/k...tion-codes.pdf
