Results 1 to 17 of 17
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Need Asap Help With Spacers
    okay so i buddy of mine who has a b7 rs4 wants to use my wheels for a show this weekend.. i have some OZ Ultraleggeras 19x8 et 35... now im not so sure on the rims size of rs4's all i saw was a 255 size tire.. so my guess is 8.5 or 9... the 8 inch ul's will be a little too far in for our liking... can anyone recommend a size spacer to give them that aggressive look we are looking for.. thanks
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Re: Need Asap Help With Spacers
    Quote Originally Posted by Ih8OEM View Post
    Oem rs4 wheels are 19x9 et 29mm, that said you probably need 6mm but they only come in 8 or 10 unless you go custom. If you need a custom set, let me know I may be able to get some but time is short.
    Dec 05 2006
    So. Cal.
    Alright, here you go:
    A stock RS4 wheel is 9" wide with a +29.
    To Make the 8" +35 wide wheel sit in the same place as the stock RS4 wheel, you will need to make up for 1/2" of wider wheel. This is equal to 12.7mm. Then you will need another 6mm to account for the two different offsets (35 - 29 = 6mm). This will bring your spacing total to 18.7mm. Remember that I say 1/2" because the other 1/2" sits on the inside of the mating surface. It does not need to be in the calculation.
    So that being said, if you get a 20mm spacer you will pretty much be sitting like a stock RS4 wheel. However, I just put 10mm spacers on my RS4 today to make it look more aggressive, If you want this look, which you do, you will need to add another 10mm to the previous figure. This will bring your total spacer size to 30mm.
    Hope this helps. It's gonna look funny behind the wheel, but for show purposes, you should be able to get away with it.
    Mar 12 2007
    Boston
    Why would he want to do this??? Bigtime downgrade. OEM RS4 wheels are WAYYYYY better looking than OZ ULs!
    Jul 02 2004
    FL
    I stand corrected.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    30 inch spacer WOW. haha. post pics at the show, wanna see the car.
    thats a lot of spacing, but i agree these calculations seem correct.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by tadhgbrosnan View Post
    I gotta say that the OEM RS4 wheel has got to be one of the best looking factory wheels ever made for a factory car. That and the CSL's on the on the BMW's, which are also hot.
    Aug 31 2007
    Miami
    well yeah i agree the rs4 stocks are way sicker then my ul's but at the show were gonna get judged and the fact that they are stock will mean deduction on points.. ok so i shall be going with 20mm spacers.. thansk alot for the help guys
    IG | @fukn_fafa
    Veteran Member Three Rings jerrym's Avatar
    Nov 23 2007
    4 Door Saloon
    You are Totally Correct sir!
    2009 Mercedes-Benz E63 AMG
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2008 Audi RS4 (gone)
    2005 BMW M3 (gone)
    2003 Mitsubishi Lancer EVO 8 (gone)
    "After a certain point, money is meaningless. It ceases to be the goal. The game is what counts" -Aristotle
    Dec 05 2006
    So. Cal.
    If you're gonna do it, you might as well just do the 30's. 20's are not gonna give you a very aggressive look.
    Jul 02 2004
    FL
    Where is the show?
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    So based on this calculation, if I want to run an 18x8 with a +35 offset and have it look like an 18x8.5 with a +35 offset, I need to add a 13mm custom spacer?
    Also, does it make sense to compare offsets when considering a wheel (and comparing against different wheels) if some wheels have positive offsets, negative offsets, or zero offsets. Seems like we're in a similar situation as comparing dyno runs taken at different times in different states.....nothing is actually equal. Please help me understand what I'm missing.
    Cool stuff with a little growl!
    Senior Member Three Rings Sleepy 1's Avatar
    Apr 03 2007
    B6A4, B5 Passat, my girls B7A4
    Put the wheels on, go to a tool store and buy a metric tape, measure where you want them in relation to the fender and have a set overnighted--don't forget 20 longer wheel bolts.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by Dodge2Dub View Post
    If you want to run an 18 x 8 and have it sit like an 18 x 8.5 with a +35, the offset of the 18 x 8 has to be (+35) - (6.35mm) = 28.65 or +29 on an 8" wheel.
    You take the additional width, which is 1/2", and take half of that figure, as half of the wheel is behing the mating surface and half is in front. So now you are left with a 1/4". convert that 1/4" into mm = 6.35mm. So if you had a 18 x 8 wheel, you would need a spacer of 6.35 to make it sit like an 8.5" wheel at +35 et.
    Feb 18 2007
    San Diego, CA
    ^^^Thanks!
    Jun 05 2007
    Syracuse, NY
    Quote Originally Posted by Sleepy 1 View Post
    Where can you find longer lug bolts for stock wheels?
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    What size spacers do I need to make my 18 x 8 ET 32 sit like 8.5" width and ~ET28 in the front and ~ET25.5 on the rear? 10mm for the fronts and 12.5 mm in the rear?
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
