Results 1 to 6 of 6
    Registered Member Two Rings oscarsaca's Avatar
    Jun 28 2007
    2007 Audi A4 2.0T 6MT
    Santa Clarita
    Installing rear valance help
    Greetings
    I just finished getting my new S-line valance painted and I am attempting to get the non S-line valance off.
    What I did: Unscrewed Both screws at the bottom of the valance.
    The Unscrewing seemed to change nothing considering that the entire valance is still fully in tact to the bumper. Also, I know there are many clips and I've tried undoing them with my hand, but the valance doesn't seem to budge in any direction.
    Help would be greatly appreciated.
    ps: I searched and all I found was - unscrew both screws and it comes right out.
    cool beans,
    -Oscar
    DUH! an Audi
    los angeles, CA
    Re: Installing rear valance help
    easy
    two screws in the bottom
    then look on the sides there might be a screw there, if there is remove those two.
    After that, start on one side and start to pull outward. From there proceed to remove the valance.
    Install is opposite, install on one side first and pop it in and proceed to install the rest.
    if you fail, drive to la this weekend and ill do it.
    -randy
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Hi!
    Had a hard time to remove mine to, but it is only the two screws.
    The thing is that the first plastic clips on both sides are attached real good and need some serious force to come out. Had to put a small screwdriver in between and pry it out.
    So in conluction, Use The Force!!
    E
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Hi guys
    Do any of you have the partnumber for the s-line valance?
    Allan T
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Quote Originally Posted by Allan T View Post
    Hi guys
    Allan T
    A4 B7 S-Line rear valance #: 8E0807521H
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Sep 28 2006
    Sweden
    Quote Originally Posted by ed@audiyo View Post
    Thanks
