Results 1 to 7 of 7
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    My car is possessed
    So my car is crazy. i got my brake master cylinder replaced. now my brake lights wont shut off even with key out of ignition, and my car will start without holding the clutch... IDEAS
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: My car is possessed
    hand brake light or warning (used pads)
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Veteran Member Four Rings Onese1f's Avatar
    Jul 22 2007
    01 A6 2.8, 03 3.2 CL
    Sunrise/Orlando, Florida
    Exorcism?
    I was lost, and I'm still lost...but I feel so much better
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Brake light switch!
    Dec 06 2007
    ^^ +1!
    -Kirk
    BetaAlphaTau Member #58
    Sep 07 2007
    Atlanta GA
    no my lights outside of my car. So you think its the brake light switch where is it and can it be fixed(without replacing)? There are no warnigs or anything like that.
    Apr 06 2007
    Pittsburgh
    Quote Originally Posted by quat View Post
    Dealer is your best bet. VW had a recall on the one they used in a lot of their vehicles. It's the same one that is in our cars. VW Part #1J0 945 511 D. Also I think its 8$ at a VW dealer but close to 15 at an Audi dealer.
    Are you sure that its a bad bulb that needs replaced? All of your braking lights could be out because of this switch. Or they stay on all the time. Its one of the major symptoms of a bad switch, the other is a non-functioning cruise control.
    The switch controls soooo many things on our cars. It's connected to all kinds of systems, ABS, Lighting, ESC, Cruise control, etc. Since you were pulling into the garage at the time im sure you were stepping on the brake pedal, thus activating the switch.
    Clicky
    That is the install on a VW, its basically the same on our cars. Just have to remove different paneling.
    This is a post I made on another thread. If you have any other questions let me know.
