Results 1 to 7 of 7
    Mar 28 2007
    ESP Light - Help !
    Hey guys, wondering if you can help me out.
    My ESP light comes on after driving for about 20 mins. Turn off the car,it goes away. Start it up and drive again for about 20 mins, its comes on again.
    Been doing searches and the only thing it comes up in the searches a bad is MAF sensor.
    Thanks again for your help guys !!
    dirtybird.
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Re: ESP Light - Help !
    Is your turbo boosting normally? I used to get the ESP light when the bolts used to back out my ATP manifold making a large vacuum leak. Turbo would reach full boost 400 rpms later.
    ReVO BT and a bunch of other stuff
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    same here.... after a few searches 1) MAF 2) carbon build up on sensor
    http://tech.bentleypublishers.com/th...ID=37499#37499
    hope it helps!
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Junior Member Two Rings 1.8tblack's Avatar
    May 15 2007
    oceanside, ca
    my car had a faulty brake light switch which caused that light to come on, because the car was seeing the brakes being on all the time i was driving. got it fixed under warrranty, no more problems. also, on my girls passat, this switch has a factory recall onit. im pretty sure they are exactly the same.
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    If I remember correctly, chris doesn't run a MAF. Keep the ideas coming though!
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Nov 11 2006
    North Webster, IN
    Oh snap, I didn't realize it was a different Dirtybird. Nevermind previous comment.
    Oh, and uh....Bad MAF. LOL.
    Oct 24 2007
    Santa Monica
    I got the same problem too. After changing the MAF, the ESP light still come up.
