Originally Posted by
Eurotuned_A4
so recently i have been thinking about getting a mroe powerful subwoofer. maybe something like a 12" jl audio w7 or w6, but is the price between the 2 worth it. reading about the speakers and etc mean nothing to me, so some input would help. any other good and powerful speaker suggestions? i wont be doing this soon, but maybe within a few months.
Seriously its whatever you want out of your system. What kinda music do you listen to we can start there?
I have all Jl Audio in my car. 2 12w6's powered by a 1000/1 and 2 sets of components.
I think first thing is first figure your budget and space. Space wise how much are you willing to lose for this system? Like for instance my whole trunk is a sound system. And cost wise its about 3000 grand in equipment in my car. Not including install. Your amps are always way more expensive then your subs are, normally. Pending on what kinda subs and amps you use.
Subs wise there is a a ton of companies out there that are good, JBL GTI series makes hard hitting subs and are not to expensive. (I think a 10" runs like 220$ on ebay.) Rockford Fosgates Power series subs arent that bad neither and again are not to expensive. Both subs run in the neighborhood of 200$ so not to bad. IMO I like the "Go big or go Home" idea, and Resonant engineering makes a sub called the "XXX" its a pretty bad ass sub. We put 4000 watts through 1 sub. (they run about 500$) Jl's 12w6 is a great sub. Good overall sound quality. Not to bad of a price. They have come down since released and are right arond 300$ on ebay. Again it all has to do with how much you really want to spend. I like the 12w7 for SPL competitions thats about it. It requires 3 cubes of space for maximum usage anything less it just sounds sloppy to me.
Your amps are a little different. You can always have more power out of an amp then a sub it truely rated for. So first thing is first find a nice D class amp. If the amp says 1000 watts of power. Its probably not really that much, look at the fuses on the side. You take your wattage normally 14.4 volts times amps (whatever the fuses are rated for) and you will get the true power outtage of that amp. Amps are a little more tricky as there is plenty of different styles, classes, looks so on and so forth. I think that if you plan on using that Soundstream amp your not going to see much improvement with spending the extra money on a new sub(pending on what kinda sub you are currently using.) I dont know a whole lot about soundstream, but from what i have seen i wasnt to impressed.
And then install wise. If you want clean and crisp sound you go with a sealed box. If you want better range, and louder go with a ported box. One sub is more then fine for most people as anything more is just a waste. And also by adding one more sub (not including cost) you will on gain about 3 db. Which for most people isnt a real big deal.
This is all my opinion of course. I have been doing custom fab on cars for many years. if you have any more questions give me a holler!
http://www.the12volt.com is a good source for questions too.
