Results 1 to 24 of 24
    Mar 14 2008
    PHX
    New intercoolers
    I am looking to put a new set of intercoolers in my car. I was going to buy a set of ERs but was told to hold off cause i was told i would experience huge pressure loss. I am running k03s. Would I be better off running the AWEs? I am located in PHX, az. It gets hot here...real hot
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Re: New intercoolers
    Quote Originally Posted by jraducha View Post
    Who the heck told you that ? An AWE or APR dealer ?
    Depending on your criteria when it comes to fitment and willness to modified your car, performance-wise speaking, it is ER > AWE > APR/RS4.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    on a ko3 car awes, or rs4s are perfect if you dont plan on going ko4s. most front mounts and ER's are kind of overkill for stage 2. i could be wrong. however i did hear someone mention that ER's may have less pressure drop that awe. dont know how concrete that source was.
    Jan 01 2005
    MN l VT
    ER's are just fine for K03's.
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    I have AWE on K03's and have no problem.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Everybody knows:
    AWE > all
    Just call up AWE and ask.
    Veteran Member Three Rings ms4cd's Avatar
    Mar 23 2005
    Slow buckets
    I have a set of ER's for sale!
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Someone please confirm the statements made by others in this thread...
    Pressure loss = greater with AWE or ER?
    I've heard that with ER, due to the massive size and thickness of the core, it could actually be prone to heatsoak overtime during long drives the same person also said that AWE coolers are the perfect size for quick cooling while maintaining adequate IATs.
    But I would like solid facts, not one sided opinions.
    Active Member Four Rings
    Jul 17 2004
    Quote Originally Posted by tike0rz View Post
    Everybody knows:
    AWE > all
    I called up APR and they said RS4 was the best. When I talked to WMS they said ER was the best. I rang China and they said Ebay was the way to go...weird.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Mar 14 2008
    PHX
    Quote Originally Posted by JayyyyyC View Post
    I too would like some solid facts...
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Larger surface area of the Er would mean more air would hit and be cooled. No way would the Ers be anymore prone to heat soak then awes smic.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Four Rings sumpsfast's Avatar
    Apr 03 2004
    '92 UrS4 - Black
    Denver/Chi-town
    Quote Originally Posted by Audi S4 Turbo View Post
    ER and AWE IC's share almost identical surface area. The thickness on the ER's is about 1/2 inch greater than the AWE's. Pressure drop.... heat soak... ? That's far fetched.
    Feb 11 2005
    E46 Bmw M3
    Quote Originally Posted by sumpsfast View Post
    I would just like to see some logs of air temp. with both Er and awe.
    -Justin
    TDI A3 Prestige
    Jul 17 2004
    In an attempt to justify my purchase of ER IC's hehe...here is some comparison data I searched and found on AW...compiled for this thread:
    1. ER vs. RS4
    RS4 (60 degree ambient temp):
    ER (45 degree ambient temp):
    These logs were done on the same car, here are some of his comments:
    "Pressure drop between the two was significant. I had about 2 psi more of boost with the ER's which caused throttle cut. So I got retuned."
    "The ER's are impossible to heatsoak though. Two back to back dyno pulls (with no cool down at all mind you) resulted in a 1hp difference. That's very impressive."
    Another ER vs. RS4 (different car...no need to point out which IC is which)
    2. ER vs. Stock
    More ER logs/data/comparisons: http://www.mnaudi.com/jprice/er_intercoolers/
    3. Random AWE logs:
    ...i'm getting lazy...but you get the point. ER heatsoak/pressure drop seems to be a myth and AWE's perform very well too...but not as well as ER. RS4's on the other hand are off the charts in comparison to both.
    Alex
    Mar 11 2008
    north east
    so does this justify a difference of 500bucks??
    for k03's... nah.
    for ko4's.... maybe-----yes
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    even if your not stage 3 yet ,upgraded IC's are a good mod to have so when stage 3 comes intercoolers would not be on the part list go ER's
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    cough cough buy my rs4 intercoolers cough cough.
    SBSC
    I also like to live dangerously.
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    i want some RS4s
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Sep 21 2006
    Norjerz
    fucking buy them
    SBSC
    Jan 07 2006
    S3%2C%20Q8
    are they in the classies?
    www.eurodrivers.ca
    Sep 21 2006
    Norjerz
    fo sho...i think. its in my long parting stage 3 for sale thread..i think. but they are for sale.
    SBSC
    Senior Member Three Rings RxDlr's Avatar
    Nov 21 2006
    Skokie
    man so i thought i was buying in advance when i got my rs4's :( you mean to tell me that it was a waste of money since i'm planning on getting either k04/rs6 or rs6 turbos?
    2007 s6 (present)
    2002 s4 (Past)
    Stage 3: VAST fueling| VAST TCU | RS4 SMIC's w/ APR hoses | milltek true dual exhaust | piggies | 710n dv's | apr bi-pipe | vogtland c/o's | hsport front and rear sways | rs4 grille | piano black trim | cc mod | EuroGEAR CF trunk and hood | RS4 reiger front | 18x8 bbs rs-gt
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Quote Originally Posted by RxDlr View Post
    Sorry to say but yes..
    AWE and ER make great products. The thing that gets me with the ER SMIC's is that Wicked used them on their GT car. That just shows you that these SMIC's can handle big power and still allow you to have the sleeper look.
    Tax Refund = ER SMIC's
    Aug 30 2007
    nyc
    i just got the rs4 ipps
    c5 A6 tip
    this n that
