I have had this high idle issue for a while (since december). Basically, my car idles high during warmup (like it should) then gradually goes back down to ~800rpm (like it should), but then it works back upto about 1000rpm and stays there.
It started with my throttle body getting sticky because of my water/meth injection getting into the throttle body plate pins i guess. So to fix the issue, I bought a used replacementand, and since, my idle holds around 1000-1200 rpm. I also get a P0507 "idle control regulation - upper limit exceeded" (something like that).
Things ive done to test the problem:
-I did a boost leak test at the turbo inlet and a test on the TIP and didnt hear anything.
-I checked teh TIP for any rips.
-datalogged the MAF readings - running at ~4-5 g/s which is too high. So im thinking it may not be a vac leak becuase the MAF is actually reading the extra air (and its not being introduced after the MAF). Or does the ecu compensate for a vaccuum leak by adjusting throttle which, in turn, gives higher maf readings?
Im running out of things to check.
Suggestions??
