let me start this off by saying , I'm not questioning if its ugly or not, its more of a matter of how ugly is it
background, I came from a mk3 VW which had a nifty rack solution that didn't go thru the door seals making it 100% waterproof and really easy to take on and off
I moved to an audi which has the conventional thule 400 foot system which does go thru the door seals
I'm not happy with the way it disturbs the door seals so I have windnoise when the rack isn't on, also I swear that I've seen the errant dop of water make it past the door seals when the rack is on
its also important to not that I'm a MPG slut and if I'm not using my rack to move stuff, I take it off
in a solution to all those issue I'm considering this:
basicaly the idea is to have small feet that are perminatly mounted to the roof, the rack will snap onto the feet and look almost the same as most B5 owners racks when its on the car
it will however look as pictured above when its off
its a perminant mod and requires 16 holes to be drilled into the roof
I'm still up in the air if its something I want to do or not
I'd like to hear your thoughts
(sorry for another blatent repost from the tex)
