Results 1 to 8 of 8
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Painting Caliper Question
    Hey guys....simple question. Could I paint my calipers with a high heat paint, 4 coats or so, and then paint it with regular paint and clear? I've painted my calipers yellow but the difference between my car and the caliper is too obvious. I have colour matched paint that I can re-coat them with but I'd hate for it to peel because of heat.....
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Feb 23 2007
    Burlington
    Re: Painting Caliper Question
    No one has any ideas? Or is this just about one of the dumbest questions ever?!!!
    Just a yes or no is all I need......I'm thinking the base coating would protect from the heat......
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Not sure how any other paint would hold up to the heat. Whether it's base coated or not, I don't think it would last long. You could try and use the clear coat that's made for wheels, b/c it is design for more heat than normal, but I still don't think it would work
    Give it a try and see what happens.
    Feb 23 2007
    Burlington
    interesting. If I sandwich regular paint between the duplicolour kit and a high heat clearcoat, that might work. I think I'll take that route. That's a long time to be without brakes though. I'll keep you guys informed.
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    Feb 23 2007
    Burlington
    ^ Re-read the first post! Colours don't match!!! Stupid Brilliant Yellow!
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Calipers don't get really that hot to start peeling paint off. I seen brake calipers, with bondo to fill holes for looks and painted with OEM paint holding up just fine.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by nebone22 View Post
    Really? Maybe he doesn't drive like I do. I'm pretty sure mine get hot enough that I can't touch them for at least 10mins after I good run/lap.
