Results 1 to 4 of 4
    Jul 03 2007
    Fairfield CT
    Need help with offset of wheels and adapter for BMW wheel???
    the wheels are 17X8 with an offset of 20. I want to put them on my 2000 s4, wondering if you guys could help me with how big the adapter width would have to be to tuck these right under the fender.
    thanks
    chris
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 24 2006
    2500 dodge ram diesel
    Boston, MA
    Re: Need help with offset of wheels and adapter for BMW wheel???
    that isnt even anywhere close to possible. they wouldstick out your fender even with NO spacer/adapter. keep in mind on an 8" wheel, you are looking for ET 35 at the LOWEST to maybe tuck your wheels a bit. (probably even ET38) the lower the offset, the more the wheels stick out the fender. hope that helps. and i doubt ull find any bimmer wheel that wll ever fit our car. try looking in porsche classifieds as they have like 50 offsets so that you can run something like a 15mm adaptor to yield the 35 et your looking for. gl bud
    01 Casa sedan 6MT, sport, cold
    Jul 03 2007
    Fairfield CT
    thanks alot man i thought that was the case
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    FWIW, I'm pretty sure you would have also run into a problem with the wheels due to their bolt pattern...BMW's are 5x120 IIRC.
