Results 1 to 25 of 25
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Low Oil Light and white crap on Dip Stick
    Im driving to werk this morn and i get the Oil min Light, i pull over dump the rest of the oil into it and check the stick, looks like there is marshmellows on the ball on top of the dip stick, i had the TB done in August and they said everything looked perfect adn no leaking any where now im smelling Coolant when i get out of the car, i dont see any spots on the ground and the level is perfect.
    Just got my taxes back looks like there all gone again unless i can do this myself
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Feb 17 2005
    Sarasota, FL
    Re: Low Oil Light and white crap on Dip Stick
    Oil and coolant are mixing most likely - head gasket
    Jun 13 2007
    Middletown, CT
    How diff is it to change the head gasket?
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by A4ringedONE8T View Post
    +1
    Quote Originally Posted by IronAudiHow View Post
    If you know what you're doing, not hard, but time consuming. If you've never done one before, I wouldn't suggest making the 3.0 your guinea pig...
    Jun 13 2007
    Middletown, CT
    can anyone give me a break down or how to from theh bentley CD as to what tools i need what exactly is required so i can judge for myself
    Jun 13 2007
    Middletown, CT
    anyone..bump
    Feb 17 2005
    Sarasota, FL
    Unless you are overly comfortable with the 1.8T in and out and re-timing the head/block, I would not do it yourself.
    Jun 13 2007
    Middletown, CT
    Sh!!T looks like the tax returns go to fixing teh head then, any idea what i can expect it to cost me
    Feb 17 2005
    Sarasota, FL
    Dealer will charge you 6-8 hours, so somewhere around 600-800 bucks
    EDIT, this is on a 3.0l? Possibly more than that ^^, I was thinking you had a 1.8T
    Jun 13 2007
    Middletown, CT
    ya its a 3.0 im wishing now that i bought the amulent red 1.8tq i was looking at, shyte. anyway ill go to the shop that did my TB, so well see how bad they bend me over.
    How long can i drive with the engine like this, i have about a 6 mile round trip to work now. so i can get away with putting like 60 miles a week on the car
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by IronAudi View Post
    The coolant is not doing what its supposed to, and the oil isnt doing what its supposed to ... I wouldnt drive the car at all
    Jun 13 2007
    Middletown, CT
    goody, so now i dont have a car and im going to need a oil change and a coolant change, that has about 10k on it GREAAAAAT
    Feb 17 2008
    Try draining the oil. If antifreeze is mixing in, it'll come pissing out then the oil will come out. Also look under the oil cap for a 'milkshake' like substance. You can also smell the coolant in the tank and see if fit smells like combustion. Doesn't sound like a head gasket at all to me, but check what I suggested.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Jun 13 2007
    Middletown, CT
    ok, ill go out and check the cap it didnt look like there was anything underneath the cap, when i had to add oil. the Oil is due for a change soon but i guess ill get that done ASAP ill order the stuff from ECS today and do it when it comes in.
    Mike02A4, assuming your right and its not the Head Gasket, what do u think it is??
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    Since your trip to work is only 6 miles and you aren't losing coolant and neither your oil or your coolant look like a chocolate milkshake, I would say it's just condensation that built up in your crank case.
    Change your oil. If it looks good, keep an eye on the coolant and avoid any cross-country trips for a bit. Also, try to not shut off the car if it hasn't warmed up fully when you get where you're going. Start it early before leaving or listen to the radio for a few when you get where you're going.
    That will help burn off the condensation that may occur on short trips.
    Jun 13 2007
    Middletown, CT
    I dont think its condensation, personally but i hope your right. waiting on the oil from ECS so i can change it and see what the deal is
    Jun 13 2007
    Middletown, CT
    ok so i checked all my fluids, besides being a lil low on oil(dont know where its going) rad fluid is pink and pretty not cloady. Oil looks like it has some yellow topping, like cake batter but it coudl be from the dip stick tube, im gonna clean it out as as much as i can to see if its really it.
    Mar 11 2008
    B7RS4 & e46Ms
    Either way...DON'T drive the car if there's a suspected head gasket leak... do you really want to gamble with a potential 10k engine replacement!?!?! if you're not sure how to spot it, pay the $60 and have someone look at it asap to give a professional diagnosis...then, and only then, make your decisions...
    let's say you fall, and when you got up, it sounded like you broke your leg, it looked like you broke your leg, and it felt like you broke your leg...would you walk on it???
    coolant disappearing = not normal
    oil disappearing = not normal
    yellow deposits in oil = not normal
    would you drive it?
    this is all null in void if you have a large bank account, then by all means push the right pedal all you want...
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    i dont' think you have all the tools and patience to do this job as a DIY. 3.0 is a bitch to work on and the room is fucking tight as hell. the best bet is turn your car in to some good shop to do it.
    if you reallly need to change your head gaskets, i'd say $130-150 for parts, but labor will screw you, so I suggest you find someone to buy some nice headers and downpipes while you are in the process.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by Maverick View Post
    I like where your heads at (pun intended)
    May 03 2007
    german
    heaven/hell
    lol, I am not selling anything here.
    just feel like make the OP's wallet bleed more, hahah
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    This whole thread seems to be very UN-helpful.
    First off, do you have WHITE smoke coming out your exhuast? If so, then you do indeed have a blown headgasket and do not drive it.
    Secondly, to me it sounds like your headgasket is fine, driving less than 6 miles is not good for your car and condensation will build up....therefore the oil will be kind of foamy-like.
    What you need to do is perform a compression test on all 6 cylinders. If your head gasket is bad you will see from the numbers produced what bank is leaking.
    What leads me to believe that your headgasket MIGHT not be bad , is that you say the coolant is still nice and pink (no evidence of mixing with oil). I would drain a little bit of it from the bottom of the radiator by pulling out the sensor, just to verify that the coolant is indeed NOT micing with oil.
    Good luck!
    -Sami-
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    If he's doing 6 miles round trip, 3 mi/each way does not get the oil up to operating temp and condensation is forming and mixing with the oil. If that "white" stuff is like a creamy consistency, I'm betting that he just needs to take his car out for a long drive and get the oil up to temp and rid the condensation building up.
    To the OP, can you post a picture of what you're describing?
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    yeah i bought a car once and showed the owner all the white muck condensation on the oil cap and valve cover. told him the head gasket was blown and talked him down big time on price heh. gotta love it when people don't understand condensation.
    if you drain your oil and its all creamy then you probably blew the headgasket or oil/water exchanger.
    change the oil, go for a nice long drive and see whats up. probably will look good. if you have water in the oil from a blown headgasket you usually will have a nasty ashy crust buildup on the plugs.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Jan 28 2007
    dallas TX
    you could have possible hydro lock... do you get a pinging noise??? if so file it to your insurance they'll replace your engine... but that much white gunk is pretty bad definitely... when i hydrolocked mine it was just as you said... and i would change the oil asap and not worry about getting the stuff from ecs... i wouldve done it next day that you found out... like the guy said above... it could be a total engine replacement... and if it pans out to be that call your insurance they should cover it.. mine did...
