Results 1 to 18 of 18
    Veteran Member Four Rings 2001S4CT's Avatar
    Nov 17 2006
    Greenwich
    High speed run concern
    Well it is 245am and I just did a high speed run on the highway. I wont say how much because a state trooper saw me but didn't bother. Well my cel started blinking so since i was going to fast to immediately stop driving, i slowed down to about 60 and shut the car off then back on and the cell went away.
    Anything i should be concerned about? Why did it do that?
    Dec 06 2007
    Calgary, AB, Canada
    Re: High speed run concern
    Possibly a misfire.
    Nov 19 2005
    Pair of (. )( .)
    boost leak?
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Jun 14 2007
    2000 S4
    Connecticut
    bring that over to ICS man, shit if i paid the amt they ask for stage 3 jobs, i would bring it there if my gas light ever came on LOL. that sounds like maybe something popped off or possibly a misfire as Jerbel said. Maybe an intercooler hose fell off? That happened to me, i was on 95 about to race an STI, and I swear to god as the thought process of flooring it went from my brain to my foot my car completley shut off, i coasted off the highway and lost all my brakes pretty much and steering. lucky i got out safe! my upper IC hose came off.
    Jun 14 2007
    2000 S4
    Connecticut
    edit, maybe not since you turned it back on LOL. just bring it to ICS let them know man.
    Nov 17 2006
    Greenwich
    but what i don't understand is that when i turned the car back on I stopped, let the oil cool down a bit and then drove home. On the way home i accelerated to see how the boost was and it was normal boosting at 22. The car is completely normal right now
    Jun 14 2007
    2000 S4
    Connecticut
    you boost at 22 on stage3-? you must be running lean city. maybe THATS why your car shut off..... threres no way stock injectors can keep up with 22lbs of boost
    Jun 14 2007
    2000 S4
    Connecticut
    for reference, i boost at like 18-17ish on 3-and when i dynoed they did A/F ratio it was almost PERFECT, a tidddy bid lean at one point but it was OK.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    How high of a rpm were you running ? If you were close to redline, I would agree with the others that you were most likely misfiring due to fuel starvation. Stage 3- setups are not created to be running at rpms close to the redline.
    Or it may be your CATs overheating.
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    if you weren't speeding maybe this wouldn't have happened lol j/k
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by 2001S4CT View Post
    22Psi on a Stage 3- program isn't normal. I'm guessing that a MBC is in use here. 22Psi near redline probably caused limp mode. Thus the flashing CEL.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Nov 15 2006
    00 S4, 99Cobra, 54BelAir
    The Milky Way
    +1 on the misfire, my car has done that at high speeds before.
    Jun 14 2007
    2000 S4
    Connecticut
    oo dam i feel smart right now. lol yeah but i notice with my VAST software if im holding down 5th gear full throttle im MAYBE at 16psi, no more. bring that back to ICS and say wtf haha.
    Nov 17 2006
    Greenwich
    yes 22 and it tapers down to 20. I should get that looked at then huh?
    Mike when I accelerate at 5th i boost at 16 max.
    It cant be cats overheating because I have test pipes no cats at all.
    And yes I was at redline cause I was well over 150mph
    Nov 17 2006
    Greenwich
    Quote Originally Posted by Daft View Post
    no MBC
    Jun 14 2007
    2000 S4
    Connecticut
    yeah bro, get that checked out. you're probably running lean as hell. tell them youre hitting 22-20 which is as people are saying a little too high for stock fueling.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    flashing cel usually means multiple cylinder misfire..
    Dec 06 2007
    Calgary, AB, Canada
    Running lean and misfiring. That's my guess. Maybe they gave you a tune for a full stage 3 by mistake??
    Take it back and get them to reflash the ECU with something a bit more realistic for 3-
