Results 1 to 8 of 8
    Dec 01 2007
    Carver
    Buying some wheels, need help
    Im buying some new wheels for my S4, I'm liking the Hartmann R8 Replicas
    http://shop.achtuning.com/index.asp?...OD&ProdID=1150
    Will these fit on my stock height s4? I'm probably gonna go 18's
    I've been reading about people having problems with the offsets and stuff, which is something I dont really understand.. any help is appreciated.
    18x8.0" ET 35
    Also, what size tires are recomended? Should I stick with 225's or go a little wider?
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: Buying some wheels, need help
    why not go wider?
    SBSC
    I also like to live dangerously.
    Dec 01 2007
    Carver
    Will they rub? I havent really read into this much..
    Will a smalled sidewall look rediculous?
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Even know the stock ride height is pretty high, but it is a fairly soft suspension so you may rub if you go wider than 225. You may need to roll the fender if that is the case.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    235/40 on stock height, you shouldn't rub. I'm about 2 1/2" lower than stock with the same dimension wheel/tire and don't rub at all. 225/45 (or 40) will look goofy without a drop though.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 25 2006
    2500 dodge ram diesel
    Boston, MA
    235/40/18s wont rub with stock ride height with your final offset of et32 (including the 3mm spacer) on an 8" wide wheels. but if you lower they car you may have rubbing on the fender depending on how low you go. 225s look nice on 8" wide wheels so no NEED to go wider unless you are looking for a bit more traction.
    01 Casa sedan 6MT, sport, cold
    Jan 11 2007
    Salt Lake City, Utah
    Get the spacer, roll your fenders and go 19's;) I just to see the 19'' reps on a B5 cause I'm considering them
