Results 1 to 33 of 33
    Veteran Member Three Rings cloudpicker's Avatar
    Feb 14 2004
    Past Bay Area-- Now--Hong Kong
    Summer is comming.. How do we cool down our Engine??
    Hi Guys,
    Summer is coming soon.. and we all know that our car is extremely hot. Any suggestions to cool down our engine efficiently?
    Heat is the biggest enemy to Turbo charged cars. the 2.7 Biturbo engine is so packed under the hood..
    Any inputs??
    I heard by taking away the Carbon Fiber pieces on the valve cover and the covers on the top of the Battery will help? is that true??
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    Re: Summer is comming.. How do we cool down our Engine??
    water/meth injection and upgraded intercoolers
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    My Sig. Check It.
    SBSC
    I also like to live dangerously.
    Jul 17 2004
    Aquamist 1S
    ...or better IC's. But buy the Aquamist instead.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Quote Originally Posted by FrimmelNoJerz View Post
    My Sig. Check It.
    How are you doing? And how's the car tear down doing?
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    ER Mutha Fukin Intacoolaaaaarz
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Oct 14 2007
    Val-Belair
    Quote Originally Posted by Jesse S. View Post
    I'll have mines by the end of this week. Can't wait to install them
    Apr 16 2005
    Pearl City, Hawaii
    Quote Originally Posted by Reich View Post
    Good luck, hope you got something to cut with.
    Oct 14 2007
    Val-Belair
    I've heard that only minor cutting in rad support was needed.
    Jul 17 2004
    There's a good chunk of cutting to the plastic surrounds the IC sits next to, nothing a dremel can't handle.
    Didn't stop me from ordering a set today.
    Alex
    Apr 16 2005
    Pearl City, Hawaii
    Yea, you're gonna be doing a LOT of cutting.
    You'll find out once everything is off.
    Jul 17 2004
    Personally, I'd rather cut plastic on an irrelevant part of the car than hack up or remove a crash bar like the alternative (for me) IC...ebay front mount... Plus, the whole stealth factor with a SMIC was a big factor, never been a fan of front mount look with pipes sticking out everywhere. Oh yea, doesn't hurt that it performs better too
    guess my point is...[fanboy]ER's FTW[/fanboy]
    Alex
    Feb 14 2004
    Quote Originally Posted by NOVAS4 View Post
    I actually had a BIG ASS DUH FMIC and oil cooler behind already..
    Just looking for even more cooling..
    Jul 17 2004
    ^ That's not a bad IC...add Aquamist and you'll be golden for the summer.
    Alex
    Oct 14 2007
    Val-Belair
    Quote Originally Posted by lil' is 300 View Post
    I agree with bumper bar, it's the main reason i choose smic. And in 2nd thought, i bielive that air will cross more easily thru cooler since there's no obstacles behind them (like condensor or radiator). And finally we only have 2'' volume less than fmic.
    Jul 17 2004
    Add to the list shorter piping for less lag and less silicone connections for places to leak...
    Alex
    Apr 16 2005
    Pearl City, Hawaii
    Oh yea make sure you've got enough T-bolt clamps.
    My wussy clamps wouldn't hold so I had to swap them out..
    I think they only give you 6 T-Bolt Clamps in the kit.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Add an oil cooler. Either RS4 oil cooler/$$$ or Matrix oil cooler/$ or Avalon oil cooler/$$.
    This will help to cool the engine down, especially for those that lives in the hotter & more humid climates. And also, flush or at least change your coolant each year before summer or at least once every 2 years is a good idea as well.
    ICs does not "help" to cool an engine down directly, it helps in preventing power loss due to heat soak and thus the need to have the engine/turbos working harder to achieve the same power output. Overheating have been noted due to excessively large FMICs without oil coolers due to the FMIC blocking off large areas of the radiator. This is why a properly designed FMIC kit will come with oil cooler, ie: Autospeed's FMIC.
    Feb 14 2004
    Quote Originally Posted by Tifosi View Post
    Thanks Tifosi, Very good Info !!
    BTW, My RS4 came stock with oil cooler and i actually upgraded to a after market Motec oil cooler..
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by cloudpicker View Post
    Didn't notice you have an actual RS4.
    In that case, what type of oil temperture are you seeing that makes you think you need additional cooling for the engine ?
    Feb 14 2004
    Yea, haha i actually own the real deal RS4..
    I maybe wrong, but i am actually looking at the water temp gauge.. I haven't put much attention, however, it's on the low side if i am not pushing the car.
    For the water temp. my car is always over 90 degree C. I will say around 91 degree C for normal cruising and 95-96 degree C after some pulls. Is that normal?
    Jun 14 2007
    2000 S4
    Connecticut
    can you tell an oil cooler only to come on in hot hot conditions? I know you dont want your oil to be tooo cool or your engine wont run efficiently correct ? how cool does an oil cooler get ya goin? i thought they were useful for the track mainly
    Apr 27 2004
    Pacific NW
    IIRC, S4's normal operating temp for coolant is ~97C so I would say you are doing just fine.
    Apr 27 2004
    Pacific NW
    The principle behind the oil cooler is the same as a radiator or an intercooler. Most of us do not need an oil cooler unless one is tracking the car, but if you are seeing a high oil temp under normal condition or spirited driving that's related to your location, it is a good idea to add an oil cooler as well. This is what's happening with the BMW 3.0 BiTurbo cars, their oil temperture gets dangerously high under just spirited driving if they didn't opted for the sports package which includes an oil cooler.
    Do a search on this subject as there are plenty of threads about oil coolers. Here are some of them:
    http://www.audizine.com/forum/showth...rix+oil+cooler
    Jun 14 2007
    2000 S4
    Connecticut
    ahh thanks. but is there a control for it ? lol that would be pretty nice if you can just say hmm i want my oil cooled NOW!. idk, i deff. dont need one though the way i drive haha i only hit WOT MAYBE once a week, just to get things movin!
    Apr 27 2004
    Pacific NW
    I don't believe so as they are too small and I imagine not cost effective to have a fan unit build in to it. Or I suppose you can add a special valve to bypass it when you want to, but I don't think it is worth the effort.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Redline water wetter is a good cheap place to start cooling down the car.
    Or move to Alaska. That should keep it cool.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    For the average person and their "close to stock" modifications (would maybe consider K04s in that category.. I am not talking about seriously modified (engine work, huge turbos, etc) to their car simply changing the coolant, upgrading the fan (which will help the radiator work better resulting in lower temps) - Vast offers an upgraded fan http://vastperformance.com/shop/prod...products_id=52, also adding water and meth injection will help drastically lower intake temps which will translate into lower operating tempratures as well. Also upgrading the fan switch so it comes on more often at lower speeds will also help lower temps as well. Oil coolers work well but unless you exceeding power out put alot the stock one should suffice for awhile and might be considered wasted money to some.
    OP - Since you already have an RS4 doing the regular maintenance will help but you might benefit most from an upgraded fan, and water and meth injection.. Only issue I see running huge FMIC's that block the cars radiator is over heating at lower speeds where air flow cant get past the intercooler to the radiator which causes over heating on hot days.. (all too common for those in the South East)
    Hope that helped and I am sure more experienced people will chime in an offer their advice.
    Cheers
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    Can water/meth kit be used as a temporary alternative to upgraded intercoolers for the summer?
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Aug 10 2007
    Quote Originally Posted by GyzmoS4 View Post
    It can be used to lower intake temps just like an intercooler can but it should never be used as a replacement for smic's or fmic's. Alot of people use water and meth injection to lower temps while they piece together kits and havent yet bought new ic's.
    Contact Scott @ US Rally Team for some great Snow Performance water/meth injection setups. Great prices and customer service is impeccable.
    Cheers
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    should we also do normal cool down like we would in the winter time(let the car sit for 2-3 mins after driving) or no boost for 5mins before parking the car.
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Feb 07 2006
    Bronx, NY
    Quote Originally Posted by Dowskeet View Post
    Cheers
    O ok, thanks for the info.
    J-Fonz tuned Stg 2+
    Aug 10 2007
    Quote Originally Posted by Bigair View Post
    Cool down defiantly helps prevent turbo failure especially with the K03s that have problematic oil feed and return lines on early S4 models. It should always be done to help maintain a nice and healthy turbo charged vehicle.
    But it doesnt help "cool" the engine down like the OP had asked earlier.
    Cheers
