Results 1 to 12 of 12
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    motul radiator additive
    anyone heard of MoCool, made by motul. its a radiator additive that supposedly can redue cooling system by 30 degrees. I was just wondering if this is safe for our cars?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Registered Member Two Rings 05a4flip's Avatar
    Oct 09 2007
    Atlantic City NJ
    Re: motul radiator additive
    I know it can reduce your pockets by a few dollars. lol jk but seriously idk probaly useless
    Mar 14 2008
    Springtown west of Fort Worth
    i thought i seen a test a while back between all the major water coolers, and only about 2 of them worked, i remember the winner was that water wetter that comes in the tall bottle and is pink in color, but i am unsure as to weather or not motul was even tested
    1999 Audi A6 Quattro Avant, 2005 Audi A4 1.8T Quattro, "the guzzler"
    <!--Will be missed -->
    2004 R32 T.Red traded it in since the road i live on now is to crappy :(
    2004 Phaeton W12 Black, 2003 911 Cab. MidNight Blue
    1999 Z3 Coupe 2.8, wow what style
    Sep 20 2004
    Paradise Valley, AZ
    i think it is pretty new. it was in the "new gear" section in european car mag.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We're running the Mocool stuff in our E30 and it's holding up great. It's designed to be used with straight water, no coolant. Have done a few track days with it and no issues with any cooling problems.
    Dec 13 2006
    02 Audi A4 1.8Tqm, 95 VW Golf
    Quote Originally Posted by Mike@PureMS View Post
    Now how will that handle for long periods of travel for us socalers in the friggin 110degree heat on the way to vegas?
    Sep 20 2004
    Paradise Valley, AZ
    is it better to run with water? would it hurt to run it with the pink coolant.
    Mar 14 2008
    water keeps the engine cooler than anti-freeze so yes its better to run with water, however if it happens to freeze in your area youd be screwed
    Sep 20 2004
    Paradise Valley, AZ
    i wonder if it would hurt to use it with g12 coolant?
    In Limbo Two Rings
    Feb 29 2008
    2000 audi a4 1.8t quattro
    durham, nc
    motul makes good products.
    i run 8100 5w40 in my 1.8t and gear 300 in the gearbox and rear diff.
    Jul 19 2007
    San Diego, CA
    The MoCool is a racing product. It's not designed to be used with coolant. And if you live in an area suceptible to freezing temps, I wouldn't at all recommend it. It does not have anti-freeze properties. It's only designed for maximum cooling along with lubrication and anti-corrosion properties.
    Sep 20 2004
    Paradise Valley, AZ
    i live in phoenix arizona. and in about 1 month its gonna be 110 degrees outside until the end of september.
    but it sound like its more hassle than its worth. i mean the reg. g12 has worked for 4 summers already. sounds like im gonna stick with g12. thanks guys.
