Results 1 to 7 of 7
    97 A4 2.0TQM
    Rochester, NY
    So, has anyone ever had to remove an ATP T25/T3 manifold?
    Scratching my head here...I don't even remember how I managed to get this thing on 2 years ago, but I sure as hell can't figure out how to get the top nuts off.
    Can't get a socket, open end wrench or box end wrench over the nuts.
    I'm sure someone here has had to deal with removing it - any ideas?
    Don't need to worry about the bottom ones, all the bottom studs broke off.
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    Re: So, has anyone ever had to remove an ATP T25/T3 manifold?
    go buy an offset wrench and put it to a grinder to thin the end of it so you can squeez it in there.
    after thinning it, cut out a small secion of the bottom to make it somewhat open-ended.
    should be work perfectly.
    this is what you want, just to clarify:
    http://alloy-artifacts.com/Photos/to...ped_inset2.jpg
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Feb 17 2005
    Sarasota, FL
    Havent taken it off yet, but used a short stubby wrench to put it on (about 4" long total length). Worked perfectly and didnt have to be ground/bent/mutalated whatsoever!
    Nov 13 2007
    it's much more difficult on transverse 1.8t's but the offset thin wrench would probably work without being ground down. it helps to have a circular end instead of open-end
    Feb 27 2005
    North Wales, PA
    go to your local pepboys and buy a cheap wrench to heat and bend. thats what i did....then i heat and bent it back and still use it till this day. lol.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    what about a crawfoot. it looks like an open end but has a 3/8 hole in it to fit either a ratchet or extension. i think that should work
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    97 A4 2.0TQM
    Rochester, NY
    Quote Originally Posted by zrowcool View Post
    tried that, they are too fat to get in there
