Results 1 to 7 of 7
    Veteran Member Three Rings audi314's Avatar
    Oct 22 2007
    06 A6 C6 Avant, 12 F-150 FX4 Twin Turbo
    ATL
    Caliper piston reset
    I have a set of front calipers that I am going to be putting on my B6 A4. I am trying to reset the pistons, and for some reason they arent budging. There is no bleeder screw in and all the fluid has been drained. What could be holding them in place? Or is there a method that I am just not aware of? Any help is much appreciated.
    Thanks in advance!
    I had a BT Audi!****> Lost at Barber MSP 11/1/09
    Hero-->http://www.youtube.com/watch?v=Q3gN6...eature=related
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Re: Caliper piston reset
    If i remember correctly they should just push in. I dont think they are twist in pistons...might want to try that
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    You only need to twist in the pistons for the rear calipers because of the parking brake mechanism. The front pistons should just be pushed straight in.
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Oct 22 2007
    ATL
    I tried channel locks to push them back in, and its a no go. Do you think that they might be seized all the way out? Is there a DIY on a rebuild for the calipers?
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Squeeze with vise.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Oct 22 2007
    ATL
    ^^ Ah thats a good idea. I will have to take them to work in the morning and try that. I hope that I dont damage them!
    Mar 30 2008
    01 Black S4
    Ohio
    If the pistons are stuck that bad, forcing them in won't leave you with good calipers. The pistons have to move back in some when you release the brakes. I'd bet the pistons won't return and will keep the pads applied somewhat. Brake fluid attracts moisture. If the calipers were emptied, and the bleeders left out, the bores are most likely rusty. Rebuild them if the bores and pistons are in good enough shape.
