Here is the VAG scan (I cleared it the first time I got it and got the same thing the second time with this being the only code both times)..
1 Fault Found:
18613 - Performance Malfunction in Cooling System
P2181 - 008 - Implausible Signal - MIL ON
I searched on here and I found two possibilities with one being easier than the other, a coolant temp sensor replacement (easier) and a thermostat (harder). without posting this exact thread before I decided to give the coolant temp sensor (against the firewall) a shot using this writeup. It went well but after I did it the problem was not fixed (the CEL has not come back on yet but i think it will tomorrow).
So before I go doing the thermostat i'm seeking some advise either suggesting something else or confirming the need for a thermostat. I am also posting this so someone else that may stumble across this problem has a search result (as I really didnt have anything exact during my search).
So i'm left with the lower coolant sensor and/or the thermostat unless someone can provide another fix.
TIA for the help!
