Results 1 to 3 of 3
    Veteran Member Three Rings audipcanugo's Avatar
    Oct 19 2005
    2009 Audi A4 Premium - Sport package
    Baton Rouge, LA
    Where is the crankcase breather valve?
    And how hard is it to replace. Anyone have a pic? The dealer just called and told me that is whats causing my car to run lean.
    Dec 06 2007
    Re: Where is the crankcase breather valve?
    check one of the threads that i started through my profile! called Have a VAC leak?
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I replaced mine in about 20 min, you just have to unbolt the hard pipe to the pcv valve on the block which connects to the intake and remove some hose clamps. If you have an 02 you might be eligible for a recall on that part. Apparrantly they did the recall based on vin numbers, and even though mine visibly ripped in multiple spots they still made me pay for it. Typical stealership bullshit.
    BTW I'm talking about the crankcase breather hose which is attached to the block or intake mani (can't remember which) but it's at the back of the engine and is a T-shaped hose. Hope that helped
