    Established Member Two Rings max09163's Avatar
    Sep 18 2007
    B6 Audi A4 1.8TM
    Kansas City
    Question Best Way to Clean Engine Compartment??
    Hey Guys-
    My engine compartment is really dirty, I want to give it a good cleaning but I dont want to get any of the sensors wet of have any chemicals on parts that get hot so they dont smoke or smell. Any ideas? Btw where can I find the four rings that go on the engine cover? thanks!
    [max]
    ---Looking for USP Lower Front--
    Also looking for top of B6 armrest center console (black)
    Registered Member Two Rings
    Jan 28 2007
    Albany, NY
    Re: Best Way to Clean Engine Compartment??
    Engine Detail:
    - Warm up engine for 3-5 min
    - Cover any wiring
    - Spray down engine w/ hose
    - Spray engine w/ 303 Degreaser
    - Take a towel and rub it in to agitate the stains etc
    - Spray down w/ hose again
    - Spray w/ 303 Protectant
    - Use towel to rub it in
    Registered Member One Ring rwohlhueter's Avatar
    Sep 03 2007
    VDub
    Auburn,WA
    yeah, i use kitchen garbage bags and cover up my electrical parts, fuse box...and i use Griot's engine cleaner, spray it on everything thats uncovered. with a soft bristled paint brush i scrub more dirty parts, then use a hose and pray it all off. I then idle for 5 minutes to help dry the engine out.
    Sep 18 2007
    B6 Audi A4 1.8TM
    Kansas City
    [max]
    Senior Member Three Rings trailboss's Avatar
    Oct 31 2004
    04 usp 1.8t, 99 1.8t gtrs
    Lansdowne VA, Waldizzle, MD
    First i do it when the engine is cold.
    Spray adams all porpouse cleaner over the entire engine bay, i try and keep it off the fenders. Let it soak and work in.
    Next i use a brush and scrub all the parts scrub everything i can.
    Next i start the engine, and quicky but lightly spray everything down. IF you hear the car studder or hicup, move the water from that area immediately.
    Once everything is wash off i take a leaf blower or you can use a shop vac, but i like to clean out the hose first so you dont spray all the dirt in the hose all over the car and i dry the engine bay.
    Next i use adams VRT over all the parts i can reach easily and then i use adams in and out spray over everything else i can't get to easily.
    So products i used were
    Adams all porpouse cleaner
    Adams VRT and detail sponge
    Adams in and out spray
    Haven't used p21s but i here its great stuff too
