Results 1 to 12 of 12
    Jan 03 2008
    Milan, NY
    PLease help! Ive had it with this car!
    Someone please tell me what the hell these codes are. We already replaced the coils! It runs like sh*t. Gets up to 2gs and it just craps out. Starts shaking and loses all power. After we replaced the coils this am it ran great for about 5 minutes then did the same freagin thing. We hooked the scan tool up to it and these are the codes we are getting:
    P0300- random misfire detected
    P0304- cylinder 4 misfire detected
    P0301- cylinder 1 misfire detected
    cylinder 2 was also misfiring before but for some reason fixed itself.
    Now the cat is over heating
    This is an 04 b6 a4 1.8t tip
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Re: PLease help! Ive had it with this car!
    maybe your popped another coil... i had 2 coipacks pop on me 10 minutes of eachother.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    So you have already replaced all four ignition coils with 4 new and working ignition coils?
    Original ignition coils tend to die out in close proximity to one another so it is always worthwhile to simply replace all of them at once.
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    id take the coils from cylinder 1 & 4, switch them with 3 & 2 and then scan for codes and see if misfires have switched as well. if so, return the 2 bad coils for some good ones.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Senior Member Two Rings tray1187's Avatar
    Feb 20 2007
    2012 Hot Chocolate Mini Cooper
    Tampa
    Check you harness connectors for your packs. I had a bad one which was causing misfires and it drove like I blew a pack. It turned out it was the connectors not making full contact with the pack. The plastic piece inside the harness that guides the connectors was broken so there wasn't a good connection.
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    I had what i thought was two coilpacks go out on me.. swapped them out.. and the codes didnt change. So i swapped in new plugs.. all better! :)
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Jan 03 2008
    Milan, NY
    Thanks guys! Ill go get the other coil packs. And try that. Its weird because its throwing the SAME code with the brand new coil!
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    Dumb questions but worth asking...
    Did you clear the codes after the coil swap???
    Jan 03 2008
    Milan, NY
    yup. the only dumb ?s are the ones not asked
    Aug 08 2007
    A4, GTI, Corrado
    Jacksonville, FL
    maybe bad catalytic converter?
    Sep 20 2004
    Paradise Valley, AZ
    when my coil pack went bad, i drove home and my cat was glowing red.
    Veteran Member Two Rings Dwaller's Avatar
    Nov 17 2004
    Dahlbach stg3+ tip A4
    L.I. NY
    Change plugs and clear the codes again.Try NGK's BKR7E gap them at .032 these are copper plugs one step colder than stock!
    Dahlbach racing stg3+ DBR intake mani,DBR ko4-19,DBR tip chip,RS4 motor mounts,ER sport front mount,Stasis SS coilover's,H&R sway's,DBR cat back exhaust,Miltek HFC,custom AFE air intake, iForged rev's 18x8.5,Stoptech BBK front ST rotor's rear,Cam's and a bunch of other sh_t!!!
