Results 1 to 11 of 11
    Mar 07 2008
    Ft. Lauderdale
    Satellite Radio Box in Trunk
    How do you remove the plate covering the satellite radio box in the trunk. I tried using a screwdriver in the small tabs on the bottom, but didn't have any luck. I want to try and avoid breaking it so I thought I would ask here.
    Thx for any help.
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: Satellite Radio Box in Trunk
    Youre doing it right. I just used a metal nail filer since it was thin and had a blunt end and poped it out. Didnt have too much resistance.
    Established Member Two Rings A4B7GA's Avatar
    Apr 20 2007
    A4 B7 5.5, 05 Exploder
    Bal Harbour, FL
    Just use two nail files or 2 small flat head screw drivers and push in and up...you can then pull it out from the top...the unit slides in on plastic rails...
    my mod list...really boring $!ht + APR
    Senior Member Two Rings Quigaboo's Avatar
    Jan 10 2008
    2008 A4 2.0t Quattro
    Bellmore, NY
    I think he is referring to the NAV cover. You can't access the Sirius unit directly from that plate. You have to remove the whole panel to get at it if there is an existing unit there. If you are looking to put one in, the NAV bay will do just fine with the velcro tape.
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    I'm going to second this post in saying I have no idea how to get that panel off. In the Avant, it's a panel with two slots down in the bottom and no matter what I use it won't budge. Help!
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Mar 07 2008
    Ft. Lauderdale
    Quote Originally Posted by Quigaboo View Post
    yeah .. i ordered an xm satellite unit (red sox games) and I want to install it so there is nothing in there right now. I wanted to open it to see if the cable is in there or if I need to get one. I thought I read somewhere that the even if your car doesn't have satellite that the bay is wired for it already, so it should be plug and play.
    Thx for the help
    Apr 20 2007
    Bal Harbour, FL
    Ok, from this point forward. Lets use photos only...When I get home, I'll do an how to...
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Im not quite sure I follow. In my trunk (05.5) there is a hatch that opens and reveals a rectangular drawer that with something thin and blunt will pop it out and it slides out on rails. When I did this it revealed my xm receiver. Your car should be wired for satellite. Now you might have to remove more to find the wires. Sorry no photos, Ill get some after work.
    Jan 10 2008
    Bellmore, NY
    Quote Originally Posted by R1NSE View Post
    Thx for the help
    Yeah that is an easy spot to get to. The cables a just inside that opening usually above the wheel well with some protective foam around the connector.
    Good luck and I am hoping the Yankees spank the Sox tonight!
    Jan 10 2008
    Bellmore, NY
    Quote Originally Posted by Latin Audi View Post
    Your receiver was probably installed at a dealership and that is the "easy" way to do it.
    When it is factory installed, there is a slot behind the left side trunk liner (adjacent to the rectangular opening) that the unit slides into. You can't get at that slot without taking the whole liner out!
    Either way we are talking about the same thing!
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Push the tabs in and slide it out, don't force it b/c its on rails that slide in/out. They need to be pressed in fairly hard to free up the door to slide open.
