Results 1 to 17 of 17
    Registered Member Three Rings
    Jun 11 2007
    Brakes differ by year?
    I drove my friend's '04 a4 (1.8t, has a lot more options than mine including sports package) and the brakes are A LOT snappier than mine (an '05 ar 1.8t, non sports package). I went to the dealership and some guy told me that they changed the caliper size between 04 and 05 but looking at the cars I couldn't tell a difference between them. My pads are OEM and still have a lot left on them. I don't know a whole lot about brakes, but I do know what calipers are and maybe there is a difference of like 20mms or so that I can't visually distinguish.
    What's up?
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Re: Brakes differ by year?
    suspension significantly helps with braking.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Jun 11 2007
    would just upgrading to the sports suspension really help that much with braking? The difference is night and day with the brakes comparing each car
    Sep 20 2004
    Paradise Valley, AZ
    i assume he has bigger tires as well.
    Jun 11 2007
    nope they're the same. I have the special edition which has the same 17" wheels, just not the suspension.
    Sep 20 2004
    Paradise Valley, AZ
    well that's weird cuz, the brake change I believe was only on the rears. And you would have gotten the bigger ones, since yours is an 05. are the tire tread wear the same? tread depth also makes a huge difference.
    Dec 06 2007
    Maybe ur brakes are bad?
    -Kirk
    BetaAlphaTau Member #58
    Jun 11 2007
    Quote Originally Posted by diztek View Post
    they both recently got replaced...both continentals
    I'm getting it serviced on thurs. What should I tell them?
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    i've been told that the brake size depends on if you have a 1.8t or the 3.0, the 3.0 uses slightly bigger ones... i ran into this issue when i had to replace my brakes
    19' Glacier S4 Black Optics
    Jun 11 2007
    yeah I heard the 3.0s are bigger also, but they are both 1.8Ts. I don't know, something just doesn't seem right. It's not that my car doesn't brake, it's just the other one does it so much more responsively and crisply.
    Dec 06 2007
    ^^ maybe it's the pads he's using!
    -Kirk
    Aug 26 2007
    whats the mileage difference on them and have either of them been replaced before?
    Jun 11 2007
    mine has 32k and the other is just under 50k. They're both CPO and have been serviced at the regular intervals so that's all I can say about that. Not exactly sure.
    BTW, where in ct are you? Just moved from there.
    Aug 26 2007
    Litchfield County area, all i can think of is maybe your low on brake fluids or your calipers are just defective of sort (like some people have factory monsters and such)
    Jun 11 2007
    ok, i guess ill suggest that to the service guys. Hope they find something.
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    the reality is suspension will indeed make a huge differance in braking in todays car's with all the active ABS technology's
    1999 Audi A6 Quattro Avant, 2005 Audi A4 1.8T Quattro, "the guzzler"
    <!--Will be missed -->
    2004 R32 T.Red traded it in since the road i live on now is to crappy :(
    2004 Phaeton W12 Black, 2003 911 Cab. MidNight Blue
    1999 Z3 Coupe 2.8, wow what style
    Jun 11 2007
    well i guess youre right about the suspension because they said the brakes were fine. they even changed the pads and fluid to make sure.
    What coilovers should I get? What are the differences between the stasis SS, Konis, H&R, bilstein, and the others?
    Also, what brakes should I get if I were to upgrade? Is it worth getting a BBK for like $2k if I don't track at all? I'm completely stock btw. Stopping power is almost more important to me than speed.
