Results 1 to 12 of 12
    Jan 10 2007
    ATL
    Questions about APR Fuel Pump and ECU Updates from Dealer
    So APR guys are telling me that I should not run that long on upgraded fuel pump and the normal 93 program. I installed the fuel pump today and was planning to get the new APR program tomorrow.
    I should keep my RPMs under 3500 and not boost too much. Sucks, but easy enough.
    I have read a couple threads on these boards about ppl getting new fuel pump and saying how much they loved it but still without getting the ecu upgrade from APR.... Then of course they like it even more.
    Based on those threads though, one would assume they were boosting high and not worrying about RPM levels.
    Right now there is this new ECU update from the dealership, which I was planned to get done tomorrow early in the morning, then go to the APR vendor and get upgraded to fuel pump software. To limit my time on the newer fuel pump without the correct software.
    Now this APR guy has me worried even more about future upgrades and such.
    Is this stock mode and 100 octane program also programmed for the new fuel pump to not cause me a problem when I switch to those?
    Curious to hear some thoughts.
    07' Sexy Red A4 2.0T * Quattro * S-line * Titanium
    APR 93/100 * APR Fuel Pump * APR Carbonio * MilTek C@TBack * 18" RS4 Gunmetal * RS4 Rear Sway * Kenwood DNX7120
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Re: Questions about APR Fuel Pump and ECU Updates from Dealer
    Since you brought up the subject; is there any increase in HP/TQ with just the APR fuel pump plus its specific software compared to the 93 octane chip?
    thx
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Jan 10 2007
    ATL
    I would assume from what others were raving about, yes there should be. apr's site shows an increase with k04 included as well, but I havent' seen any other dyno's from other users. :)
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I did the Test pipe and the Fuel pump at the same time. The software that was upgraded on my ecu was just the test pipe software ... The care felt good but I was still a little blah about the money I had just spent ... when I went back They checked it out and saw that it was a Stage 1 with Tp software .. not the Stage 2 & TP software... they updated my software on the spot ... I went for a drive afterwards .. and MANNNNN WOW what a difference .. No fuel cuts what so ever and it pulls nice and hard all the way through. I have not Dynoed the car but plan to in the near future .. just been to bussy with work.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Jan 10 2007
    ATL
    so no one knows the answer to the question of whether you need to baby your car with APR Fuel Pump and no software?
    Feb 21 2008
    09 Q5 Ibis White
    ok so I spoke with a local Apr dealer and they told me that there is no issue if you run the apr fuel pump on Stock or apr 91 software. Now the thing is ... if you already have APR software... why wouldnt you get the software update for the pump?? it should not cost you a dime to upgrade ! Now From I was told .. the latest dealer updates are available on the APR software now. I am goin to go in tomorrow morning to get re-flashed with the latest update. Hope this helps ya bud
    06 MkV 2.0T - Sold
    Nov 05 2007
    Auburn, AL
    Quote Originally Posted by lokeh View Post
    Lokeh:
    Running Upgraded Pump without Pump Software
    There is no huge danger with running the upgraded pump with your existing, non-pump software for a short period of time. However, the control strategy for the fuel pump MUST be upgraded due to the larger flow capabilities of our pump compared to the OEM design. The reason is that the original control strategy for the pump pressurization solenoid is designed around the fuel displacement of the original pump. Since our pump flows up to 40% more fuel, the original solenoid control strategy is no longer valid. This could lead to drivability issues, fuel adaptation issues, etc. If anyone on Audizine knows anything about control systems, they know that the control loop tuning must be right to ensure there is no odd system behavior. Not having the proper pump control software would be like have an improperly tuned N75 valve and expecting your boost pressure to always be on target...it doesn't work.
    We recommend that all of our customers get the software installed as soon as the pump goes on the car. However, you should be okay to get the pump installed and drive the car to the APR dealer the next day. However, I would drive normally and not push the system until the correct software is loaded. I am not guaranteeing you will have an issue if you don't obey this rule, but I can guarantee that it is not a good idea to run the car hard with the wrong pump control strategy.
    Power/Torque Gains with Upgraded Pump
    As far the questions about the power/torque increase for the fuel pump...
    We typically see around 10whp and 15lb-ft at the wheels with the upgraded pump on standard 2.0T applications. We have seen better numbers on the 2.0T's with the larger turbos like the Audi S3 where typical gains are around 15whp and 25lb-ft at the wheels. The gains we see on any 2.0T are due to the fact that we can be a little less conservative with the boost pressure in the mid-range where the OEM fuel pump has the most trouble keeping up.
    However, the thing to keep in mind about the fuel pump upgrade is that the majority of the gains people are feeling have a lot to do with the "area under the curve" gains that the fuel pump provides, especially in the mid-range. This is where the upgraded pump and software really shines and gives the 2.0T that feeling of great bottom-end torque. Therefore, the gains you see in torque from the fuel pump will actually show in the peak torque numbers because the larger pump is doing what the OEM pump cannot due at the mid-range RPM's where torque is the greatest on these cars. However, the biggest gains for horsepower on a stock turbo car will show in the mid-range RPM's, well before the peak horsepower RPM has occured. This will be that "area under the curve" gain that I spoke of. So, you may not see a PEAK horsepower gain (most people do) but you will see a definite horsepower gain in the mid-range around the same RPM as peak torque. This allows for a broader power band and really helps the car feel punchy and pull hard without any dips in the powerband. Search Audizine for APR Pump and see how many customers can feel that mid-range torque and mid-range horsepower bump. These cars run great when the fueling system has a little bit of headroom.
    I hope all of this made sense and I didn't confuse you. The gains are real, they just happen in the mid-range of RPM's.
    Preventative Maintenance
    Also, and this is the most important thing I can say here..
    Did you inspect your camshaft and follower per the instructions in the fuel pump box before you installed the pump? This can be done so quickly and can save you tons of possible headaches in the future due to a warranty issue Audi/VW is having. If you haven't read the instructions in the box...go here...
    http://www.goapr.com/Audi/support/fs...stallation.pdf
    Jan 10 2007
    ATL
    Quote Originally Posted by VZWalex View Post
    as i stated I was going to get APR software update tomorrow but i HAVE to drive on it tonight which I did and tomorrow morning. I just wanted to know if I need to worry about baby'n it or if I can drive normally with boost :P
    I drove it like I was instructed, it boost some but mostly stayed out of boost on cruise and kept my RPMs down...
    MIKE - Thanks. Sorry I didn't see that on your site when I looked earlier, would have definitely saved me some time. :)
    I had the local shop check the Cam and they said it looked fine. I sent them all of your links on that.
    Feb 21 2008
    09 Q5 Ibis White
    looks like you got your answer bro. enjoy the new pump! *no pun intended*
    06 MkV 2.0T - Sold
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Just to give you a heads up. I recently had the FSI pump installed with the upgraded software. The power is alot more present in the mid-range. I got the car on the dyno and put 240WHP and 277WTQ down on my mods. On a mustang dyno.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Jan 10 2007
    ATL
    nice looking forward to the smooth and nice power. :)
    I hate a late start this morning getting my ecu reflashed from dealership, so probably go by the shop to get latest apr software at lunch time.
    Jan 10 2007
    ATL
    finally was able to drive on it some with the upgraded software.
    I also bought 100 and stock program as the 2 for 1 was being offered.
    The Fuel Pump software feels very smooth and can definitely notice a moderate increase in power in midrange RPMs. I am definitely enjoying it.
    Now hoping they hurry up with the Stage III for this summer.
