Results 1 to 2 of 2
    Mar 21 2008
    Waterpump quesitons
    Can it be done by myself?? any writeups if so??
    What tools will be needed.
    Dealership wants 900 to replace just the waterpump.
    Thank you for any information regarding :)
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Waterpump quesitons
    The water pump is part of replacing your timing belt. You can defiantly do it yourself. There are a couple how to on audiworld.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
