Results 1 to 16 of 16
    Senior Member Two Rings 05UltraSprt's Avatar
    09 Armada (4 Kids, gotta have it)
    Fort Myers, FL
    Engine temp fluctuating between normal and hot
    Good morning all,
    I did a search, but didn't find anything definitive. Yesterday, the temp gauge starting rising, stopped at about the 3/4 mark. Stayed there for a minute or so, then dropped back down to normal operating temp. Five or ten minutes later, same thing. Five minutes after that, same thing, but the temp made it a little higher on the gauge. That's it. Every time it starts to rise again, it goes a little higher. It stays hot for a few minutes, and then it goes back down.
    Checked the fluid - It's full
    Checked for codes - I have one, for a MAF, but it's been there for a week or so (haven’t gotten around to ordering one yet)
    Checked for leaks - nothing I can see.
    Fans seem to be working fine.
    First thing that comes to mind is a sticky thermostat, just wanted a second, third, fourth and fifth opinion.
    Any help would be greatly appreciated.
    TIA
    Oct 16 2006
    Naperville
    Re: Engine temp fluctuating between normal and hot
    this happened to me once... it was a thermostat. it got hot when i was parked and went back to normal when i started driving.
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Coolant temp sensor.
    ReVO BT and a bunch of other stuff
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Have you replaced the coolant temperature sensor in the back of the cylinder head?
    If so, then my next guess would be the thermostat.
    Here is some info on the thermostat: http://audizine.com/forum/showthread...38#post2438838
    -Doug
    Oct 16 2006
    Naperville
    BTW if its your coolant temp sensor, audi will replace for free!!!
    Fort Myers, FL
    Replaced coolant temp sensor & thermostat this weeend, still having the same problem. Anybody happen to have any other ideas??? The system builds pressure as intended, the fans turn on as intended. I should note that I have not changed the coolant temp sensor in front, only the one near the firewall. I guess I'll try that next. Maybe I'll just drop it off at Audi tomorrow and let them deal with it.
    Anyway, any other suggestions would be appreciated...... Thanks.
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    I always tought fluctiating temperatures were because of an air bubble inside the system. Could that be happening here ?
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Did you purge the air from the system? there is a bleed screw on the upper radiator hose hard line (ontop of your intake).
    -Doug
    Fort Myers, FL
    My coolant slowly leaks from that screw - Cheap ass platic thing. So, I'm going to assume becuase I see water coming from there, it's bled.
    On a side note, isn't there a metal replacement screw available for that bleed valve?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I'm fairly sure the bleed screw on my car is metal. It never leaks. There's a copper washer. Perhaps replace that first?
    -Doug
    Fort Myers, FL
    For those that may have been wondering what the problem was....
    ....and that's at 71K miles.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    72K miles is pretty good for the water pump...
    Fort Myers, FL
    Yeah, I guess I learned that the hard way...
    Had I known, I would have done the pump and the belt 10K miles ago.
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    Quote Originally Posted by 3thrd_a_4 View Post
    x2.... absolutely
    Ooooppppsss..... I didn't see your pic of the broken water pump.
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Plastic impellers? Seems like a good case for getting the upgraded metal impeller type that is out there (see ECS Tuning website)
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Fort Myers, FL
    Quote Originally Posted by drmarcj View Post
    Yes, stock pump has a plastic impeller (POS). ECS Ultimate kit is in there now, along with a few other ECS goodies...
