Results 1 to 8 of 8
    Senior Member Two Rings galvan11's Avatar
    Aug 20 2007
    02 pearl gt s4, vw passat, 06 cbr
    south
    Two things that have been buggin me...
    I have come to notice how heavy and non smooth the throttle has became recently.After changing my oil about 1000 miles ago my throttle and car felt so smooth. I also just recently upgraded to the samco tbb and 710n's and checked for boost leaks but it all seems good to go.I just did the 80k service about 5k ago too. The car just feels so SLUGGISH recently!Anything to look out for or replace?
    Another concern I have would be the handbrake light coming coming on whenever i go WOT at higher speeds. Obviously the handbrake is all the way down. Any suggestions?
    Thanks in advance!
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Two things that have been buggin me...
    For the handbrake, the brake fluid may be low. When it shifts at speed it might be triggering the sensor.
    the homebrew'd s4
    Dec 06 2007
    Calgary, AB, Canada
    The handbrake doesn't depend on fluid.
    That light isn't a handbrake light, it's a brake light. And yes, low fluid usually is the cause when the light comes on under acceleration.
    Have you VAG'd the car? Do you have a boost gauge?
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Quote Originally Posted by galvan11 View Post
    Thanks in advance!
    What do you mean by sluggish? Do you have boost still? Are you slow to start? What?
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Mar 15 2007
    New England
    Quote Originally Posted by The_Jerbel View Post
    Thats what I meant, the brake light that comes on when the handbrake is triggered.
    the homebrew'd s4
    Aug 20 2007
    south
    Thanks for the replies.
    Ill be checking the brake fluid this weekend and ordering some spark plugs. Im sure that will make a difference.
    I also have some whistling type noise whenever the car spools. Whistles as the car starts to boost and whenever I let of throttle. I just got two brand new turbos and changed out tbb and dv's but the whistling still persists. The whistling type noise keeps on getting louder every day it seems. I know it has to be a boost leak somewhere bc every time I go WOT,the car hesitates. I don't know what else it would be but I cant seem to find that leak. No i don't have access to a vag-com as of yet. No boost gauge yet. Both on order right now.What could i check in the meantime?
    TIA
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    ^ Don't be going wot till you get that sorted out. It sounds like someone forget to hook up a line and you have a boost leak when they did your install. Going wot will fry those ko3s fast when you have a boost leak.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Dec 06 2007
    Calgary, AB, Canada
    ^2nd. Do a boost leak test ASAP. Don't go WOT until you do.
