Results 1 to 12 of 12
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    turbo timer install help *PICS
    ok i followed the writeup ( http://www.audiworld.com/tech/elec98.shtml ) and here is my wiring setup, ground is bolted to fuse box bolt, red tt power is on 30, inline fuse is on 75x, vag wire is tapped to tt green wire (blue in picture, because of extension wire). hooked the battery up and the turbo timer wont turn on. its a greddy full auto btw
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: turbo timer install help *PICS
    make sure you ahve all the grounds grounded. that was my problem
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    i have it grounded to the fuse box bolt , i have my boost gauge light grounded to the other bolt and it works, is this a bad spot? (boost gauge light top, tt bottom)
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    ^ That will mess you up. I have a TT in the mail would you mind circling or arrowing the 75x cable(for power right).
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    i have the inline fuse hooked up to the 75x (this is the wire from the #6 fuse in box)
    Jun 04 2007
    Austin/DFW, TX
    hey 20v, I did my ground exactly like yours, its perfectly fine for me.
    I hate doing electrical crap
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    When we cut the blue black cable ,one side goes to 75X with an inline fuse box with red wire but the other end of the wire isn't supposed to be the same wire that was connected to VAG connector? Will we leave the black/blue wire open circut (fuse panel side) and connect the TT's green to the black/blue wire which is on the VAG connector.If its the samee wire why do we use the connector side insted of fuse holder's side ?
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    the vag i wire is supposed to be hooked up to the turbo timer (green wire)
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    When you cut the black/blue wire ,fuse side of the wire goes to 75X.What about the other terminal of the wire ,are you leaving it open circut ? or it2s the oposite.
    Feedback: Clicky
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    what does grounding a wire mean? can you just attach it to any metal nit or bolt that's on the car? :| yea..I'm an electrician dummy :|
    TEAM|AXION
    Dec 05 2007
    CA LA
    any thing metal should be grounded to the frame. witch is 1 BIG ground
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Quote Originally Posted by prodrive View Post
    im kind of confused at what you're saying hopefully this clears it up. black/blue wire (cut from fuse 6) is connected to one side of the inline (5 amp) fuse, and then connected to 75x. i removed the #6 fuse and put it in the inline fuse (so now #6 fuse is removed from box and wire is not connected to box)
