Results 1 to 13 of 13
    Apr 07 2008
    Fort Collins, Colorado
    In car turbo removal?
    i looked through the DIY and did a search and found nothing...
    My turbo is a howling beast now and I found a guy local that will rebuild it for 150 bucks(might just try and do it myself) and he can also put on a k04 inlet side housing and impellar... not sure how much...
    back to the point...
    how hard is it to yank the turbo out?
    is it as simple as:
    remove air box
    disconnect cat
    disconnect the oil and coolant lines (oil lines are under the turbo right)
    remove that dumb support bar
    take off the intake hose (do it last to keep crap out of the turbo that is going to be taken apart and cleaned anyway)
    anything else?
    is $150 fair for a rebuild that will only take a day to get my turbo back?
    are there any tricks I am unaware of?
    and i forgot about the three obvious bolts on the manifold...
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Re: In car turbo removal?
    for 150 on a rebuild? thats hella cheap, almost suspiciously cheap.
    --Black 2001.5 -S4- 10secS4 Tuned
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    sounds like you about got it, you might want to remove the manifold to make it easier. Getting the stubborn bolts out are the worse though. make sure you have a good set of Allen ratchets
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 07 2008
    Quote Originally Posted by biketsai View Post
    I have a spare AWM engine that we took the turbo off of and I am not too sure about getting all like 20 bolts off the manifold, and then putting the back on while in the car...
    is it worth the 2-6 hours it takes to drop the engine to get them out?
    Apr 07 2008
    Quote Originally Posted by Grangalan View Post
    we hooked him up with some good parts for cheap so he is hooking it up...
    is it worth it for me to upgrade to a k04 shaft and inlet housing?
    Veteran Member Four Rings CaSp3r9's Avatar
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    If you're confident/mechanically inclined enough to do it yourself then I'd say go for it. It's pretty straight forward for the most part and it's always fun to tear your car apart haha. But don't try to rebuild the turbo yourself, it needs to be balanced on a machine at a shop, it's not something you can do in your garage.
    Here's a writeup I found on Audiworld...
    http://www.audiworld.com/tech/eng27b.shtml
    Good luck!
    1998.5 A4 1.8tqms, Sold
    2006 A4 2.0tqm
    I have a VAG-COM if anyone in the Santa Monica area needs it.
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Quote Originally Posted by hossified View Post
    Depends on how much it costs, if it's cheap - why not? I'm not entirely sure if it is necessary to have software written for a k04 on something like this tho... anyone know?
    2006 A4 2.0tqm
    Apr 07 2008
    Quote Originally Posted by CaSp3r9 View Post
    Good luck!
    Thats a big help, the write-up is pretty solid... As I continue to wrench and part these cars out ill try and get some decent FIY write ups for some obscure parts...
    Taking the stuff out is easy, I am more worried about reinstall...
    Jun 04 2007
    Austin/DFW, TX
    Reinstall is just as easy, especially because you dont have to get stubborn bolts out with bloodly hands
    My 5-Speed Swap DIY
    - B6 USP
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Amen to that haha
    2006 A4 2.0tqm
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    I removed my AC compressor to make removal easier, especially to get to the support bracket bolt. Removing the manifold is totally unnecessary, it just makes more stubborn bolts to get out. My only recommendations are to buy a hex socket to use on the support bracket bolt and take it out from the bottom with the help of some flex bits. To unbolt the turbo from the manifold use some extensions to get the ratchet higher than the car body, I hurt my knuckles a lot when the socket slipped off the bolts. The turbo to exhaust bolts were hard to get at, i ended up doing it without a racket, just used a long extensions, a flex bit and a 17mm? bit, turning the extension 90 degrees and using it to turn the bolt was the easiest way to do it.
    Apr 07 2008
    I think I am set on the tools I need, just waiting to get my econ stimulus or tax return and ill only be out of the car for a day or two...
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    to get the turbo out and back in count on 4 - 6 hours depending on how many times you've done it
