Results 1 to 9 of 9
    Feb 19 2008
    Dash light replacement?
    Hey I noticed that on my Headlight switch, a section where the little symbols are, is burned out. Are there replacement bulbs I can get... I found this little how-to on how to take apart that portion of the dash. (I DID NOT WRITE THIS HOW-TO)
    http://www.mpaxconsulting.com/audi/trim.html
    DASH TRIM (LEFT)
    The short piece of trim near the headlight switch is the most difficult part to swap. To begin, remove the cover on the outside using the screwdriver and paper technique. This will pop a little section off big enough to get your fingers under and then just pull it out. It will resist a little bit, there are four plastic clips holding it in, just pull it straight out. This will expose the fuse box. Then you need to remove the lower part of the dash under the steering wheel. To remove this, there are two bolts located on the bottom. Remove these and pull the whole thing towards the seat. Keep in mind that there are wires connected to this piece, so you can not take it out unless you remove the wires. I didn't, I just lay it on the floor.
    There are 3 bolts holding the trim in place (marked above). To remove these you need your new best friend, a 5/16ths socket with a screwdriver attachment and a socket wrench.
    Most of the bolts can be removed with the screwdriver extension, the one nearest to the steering column will require a socket wrench because you can not get the direction/cruise control levers out of the way.
    Once you get the bolts out, you need to remove the headlight switch assembly. To do this, you must turn the headlight switch just to the left of the "Auto" setting and push in, you will feel when you are in the right place because it will go in about a half an inch. Then turn to the right about 10 degrees and pull straight out. This took me a couple of tries, but when I got it right, I could feel it.
    Feb 19 2008
    Re: Dash light replacement?
    no Help?
    Junior Member Two Rings LTrain2273's Avatar
    Apr 01 2008
    Minneapolis, MN
    5/16" No!! 8mm
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    you can order them from autohausaz, i replaced 3 of them on my A6 last month
    1999 Audi A6 Quattro Avant, 2005 Audi A4 1.8T Quattro, "the guzzler"
    <!--Will be missed -->
    2004 R32 T.Red traded it in since the road i live on now is to crappy :(
    2004 Phaeton W12 Black, 2003 911 Cab. MidNight Blue
    1999 Z3 Coupe 2.8, wow what style
    Feb 19 2008
    Osram Sylvania
    Bulb; 12V/5W Glass Wedge Push-in Type
    These ones?
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Why would you remove the knee bolster to get the headlight switch out? And SAE, really?
    Mar 14 2008
    Quote Originally Posted by FrostofSparta View Post
    Osram Sylvania
    These ones?
    no probably these ones since you can't pull the bulb out of its socket cuz its glued and soldered and trying to solder something that small is a total pain...
    https://www.autohausaz.com/search/pr...ber=4A0919040C
    Feb 19 2008
    Awesome thanks for the help... Now i'm just curious what it looks like near the headlight switch and how easy it would be to switch it out... (the light that is out)
    Mar 14 2008
    on my a6 it was easy as pie, just took the cluster out, took a small slotted screw driver and 1/4 turn took out bulb put bulb back in 1/4 turn and done
