Results 1 to 25 of 25
    Senior Member Two Rings giacb6usp's Avatar
    Sep 17 2006
    05 A4 1,8T
    Long Island. NY
    Just replaced Valve gaskets...took some pix.
    After class, we were looking for some fun and decided to change valve cover gasket for my friend's and my A4. Here are some pix...during the thing...
    USP CLUB MEMBER #4
    K04 - Miltek Exhaust - PSI TP - Racetec FMIC - TT 225 - SB OFE SS - AWE Boost Gauge - AWE Tuning Pedals - Forge 007P- RNS E - Oettinger - Apexi TT - Fujita Filter - S4 F.Grille - ECS D.Mirror - Hawk HPS F/R - Hardwired V1 - Hitachi E CP - Bosch FR5DTC - H11 Höen Xenonmatch - APR Snub - VAG-COM License with HEX-USB+CAN Interface -
    Dec 06 2007
    Re: Just replaced Valve gaskets...took some pix.
    dang that thing looked dirty
    -Kirk
    BetaAlphaTau Member #58
    Dec 19 2007
    York, PA
    nice, ive been there and done that...especially the cleaning part...ugh...
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    do you have a DIY for this? I've been meaning to do this
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    I need to do mine just been really lazy lately.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by GTMRS4 View Post
    Pull the coilpacks, remove the cp harness ground (10mm), take off the (9) 10mm nuts and pull it off
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    What is safe to clean it with?
    the homebrew'd s4
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I need to re-do mine.....
    mainly because i want to polish it off the car!
    Oh and Shawn...it was NOT that easy for me.....there were all those airlines in the way and the oil feed line was also tied into the valve cover as well.....I dont why everyone says it is super easy, but for my car it took for ever!!
    maybe they changed it after 2002?
    -Sami-
    Sep 17 2006
    05 A4 1,8T
    Long Island. NY
    Quote Originally Posted by Overboostin View Post
    H2O....
    USP CLUB MEMBER #4
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    and what exactly does cleaning it help do?
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Feb 17 2005
    Sarasota, FL
    I can change mine in 5 min or less ... and forgot about all that crap thats SUPPOSED to bolt to it on the side, lol. And the crankcase vent, but thats a quick clamp, just squeeze it with plyers and slide it off
    Helps when nothings in the way!
    And whoever asked what to clean it with, brake cleaner works well
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by giacb6usp View Post
    H2O....
    Water isnt going to touch oil, brake cleaner is best as I said ^
    Oct 16 2006
    Naperville
    I love seeing my old RS4 cover..... :)
    Quote Originally Posted by A4ringedONE8T View Post
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Simple Green and water did the trick on mine. Seems less noxious than brake cleaner, so I don't have to open my garage door when it's -10 outside.
    Yes, the newer 1.8T (AMB) has a lot more stuff on the valve cover than on the older B5 (AEB).
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Dec 19 2007
    York, PA
    i used aircraft remover to eat it off quickly the first time, carb cleaner works great too
    Feb 19 2007
    Charleston, SC
    I replaces my valve cover gasket less than 10k miles ago....if I take my valve cover off to polish it and clean the underside (I was too tied the first time , lol) can I reuse my USED valvecover gasket?
    Wheres the cheapest place to buy one?
    Also where are the six points to put RTV? I only put them in 4 points last time and it still leaks a bit....
    -Sami-
    Jan 18 2007
    Lexington Ky
    Anyone have a DIY or has done a Cam tensioner seal before?? i know they go bad on 1.8T's on the vw's and audis and been thinking about doing it recently.
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    for DIY!
    my car needs this so bad... soon I guess...
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    I never had to clean my valve cover since Auto-RX did all the cleaning for me =)
    another stereotypical Audi
    Oct 29 2005
    10speed
    San Francisco, CA
    Shawn where do you vent that line that is supposed to come down on the side of the VC?
    - Clint
    Feb 14 2008
    xxxx
    Quote Originally Posted by KraftwerkB6 View Post
    Anyone have a DIY or has done a Cam tensioner seal before??.
    Passatworld to the rescue! This is for the AWM engine - should be pretty similar for AMB and AEB, except for maybe a few bits and pieces you have to remove to get the valve cover off.
    The Haynes manual (B5) has a little picture of a DIY cam tensioner tool that might be worth investigating.
    Senior Member Two Rings keithla4's Avatar
    Oct 31 2007
    02 audi a4 quattro man
    oregon
    for the inside i have used paint remover from a parts place it works really good.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by drmarcj View Post
    I couldnt figure anything out with the AMB. I got an hour in and had to put it all back together. I gotta go buy a whole whack of rings to replace the one time use clips
    Feb 19 2007
    Charleston, SC
    -Sami-
    Sep 24 2007
    Woodbridge, Ontario
    Hey man, Give me a guide for AMB lol! How much of all that shit at the top of the VC and the side do I have to disconnect!
