Results 1 to 19 of 19
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    Cranking but Not Starting! Help!!!
    Here's my story.
    The engine died on me while driving.
    It will crank, but it won't start.
    I tried to figure out.
    There's no fuel flowing in the fuel line, and there is no spark.
    When I turn the ignition, the rpm doesn't response.
    I checked the temperature sensor, but it wasn't the problem.
    I think it might be the crank sensor or cam sensor.
    What do you guys think the problem is???
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Re: Cranking but Not Starting! Help!!!
    you should have a check engine light.i would guess the sensor on the drivers side of the trans bell housing
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    are you out of gas?
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Apr 01 2008
    Massachusetts
    No...I filled it up on that day the engine died...
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    and your sure of no spark., a little fyi if there is too much alcohol in the gas an audi pump has been known to fail. i replaced a tt fuel pump 2 time to find this out.get a little of the gas and pour a small amount on the floor and let it dry, does it leave behind an oily residue? if so the gas should be ok.
    Oct 30 2006
    B8 A4 Avant 6spd
    Check your fuel pump fuse.
    -18 718 GTS
    Apr 01 2008
    Massachusetts
    I am sure there is no spark, and I also checked any fuses that might be related.
    And also, while taking a part of intake, I found out the Y-shaped pipe was very wet with some residue.
    It began right before the silver y-pipe, and continues.
    Is that normal?
    Aug 10 2007
    Castle Rock, CO
    Quote Originally Posted by mike's machine View Post
    Is that normal?
    yes.
    So to recap, you have power to the starter, but no spark and no fuel, correct?
    Are you chipped?
    2000 s4
    Fairfield, CT
    does its sounds like it cranks really fast or normal. if fast you have a broken timing belt
    i heart my s4
    2000 s4
    Fairfield, CT
    if your belt broke there will be no responce from cam or crank sensors because, the belt is broken and everything is off.
    i heart my s4
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    Have you checked for error codes yet?
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Apr 01 2008
    Massachusetts
    It's not timing belt. It cranks like normal.
    And it's not chipped...I was making sure everything is nice and tight so I can get some upgrades done!!!
    And I don't have the reader for error code...
    I just ordered a crank sensor, it cost me 145 bucks...
    I'm going to try that, what do you guys think?
    Jan 16 2006
    Vancouver, Canada
    You need to check the error codes before you spend any money on parts.
    2000 s4
    Fairfield, CT
    if you want to buy oneof everything and stuff it all in a cannon and shoot it at your car one of those parts is bound to fix it. so dont waste time and money and have someone properly diagnois it.
    try checking the Ignition control module on top of the air box. that can cause a no start.
    i heart my s4
    Apr 01 2008
    Massachusetts
    checked all the sensors, they all seem working. All have proper currents flowing.
    It still cranks, spark, no fuel...no check engine light...
    We hooked it up to computer, and it could not recognize it.
    Would it be problem with ECU?
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    yea if your "EPC" light does not come on with the car on the "ON" position, theres no communication. also the scanner verified this. try another ecu.
    2000 s4
    Fairfield, CT
    no fuel...please got tell me you checked the fuel pump? did you recently put a filter in in it cause they only go one way. acutally you cant mess that up cause they banjo bolts are diff sizes. but if you didnt chek there please do
    i heart my s4
    Apr 01 2008
    Massachusetts
    yea ECU...and no, I got the engine oil changed a while ago...
    Apr 01 2008
    Massachusetts
    Got a working ECU with GIAC, it's working FINE!
    Now the clutch's gone! Damn!
    http://www.audizine.com/forum/showthread.php?t=207971http://www.audizine.com/forum/showthread.php?t=207971[/URL]
