Originally Posted by
Sniper512
...Also it absorbs vibrations allowing your car to advance timing more because the knock sensor is seeing less vibrations. The car just feels lighter as well thats the best way to explain it.
What?! Who told you that, the salesman?
The knock sensors operate at a very specific frequency (typically ~2-5KHz on many engines), which are interpreted as voltage rises and/or drops. These readings are then filtered by the ECU to ignore other engine "noises", so that the proper amount of timing can be adjusted during instances of predetination.
I don't doubt the car's acceleration is improved for the other reasons metioned though
