Results 1 to 26 of 26
    Junior Member Two Rings mwc951's Avatar
    Nov 24 2005
    '01 A4 TQM, '88 Porsche 951, '99 4Runner
    Native Appalachia
    Fighting Front Shock Install!!
    I'm installing struts on my '01 A4 QM. I got the dirvers side in after 5 hours.
    I can not seem to remove the passenger side assembly though. After 4 hours
    of fighting it I walked away. The sway bar link is loose, two upper mounting bolts and the lower shock mounting bolt. I can't get enough clearance to lift the "wish-bone" on the bottom of the shock to lift above the lower.
    Any help is greatly appreciated!
    '01 A4 1.8TQ M - APR Stage I, 2.75" Borla w/test pipe, APR Snub Mount, RS4 Reps, Forge BOV, ECS Race N75, APR T I P
    '88 951 - K27/6, etc, etc, etc, 380rwhp
    '99 4Runner - beater/boat hauler
    '86 Subaru BRAT
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Fighting Front Shock Install!!
    show me a picture, you might have to use another jack to pry the strut out of place
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by mwc951 View Post
    Undo the two 13mm nuts as well as the 3 17mm bolts on the strut mount assembly. You'll get enough clearance that way. Also, which way do you have the wheels turned?
    Nov 24 2005
    Native Appalachia
    I'm not able to the the lower control arm dropped enough and/or get the shock lifted high enough to clear the lower.
    I've tried turning the wheels...that was the only way I get the drivers side out.
    '86 Subaru BRAT
    Jan 29 2007
    08 S4 00 S4
    MD
    release the whole upper strut mount assembly from the car, the 3 17mm bolts and two 13mm nuts. It'll fall right out..
    Nov 24 2005
    Native Appalachia
    Thanks so very much...
    I'll give it a try.
    '86 Subaru BRAT
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    ^^^^^^^^^1000
    GIAC-X, STASIS TS,VAST,034 MS
    Feb 27 2005
    North Wales, PA
    do you have both front wheels off the ground?
    you can use a big adjustable wrench over the lower control are to tweak it to get the bottom mount up and over.
    Nov 24 2005
    Native Appalachia
    Both wheels off the ground...
    Wheels turned towards drivers side...
    3 17's holding strut mount out...
    Shock WILL NOT clear the lower!!
    I need a helper, to push down on the entire assembly while I maneuver the shock.
    Tomorrow I'll have access to a buddy to help.
    What a PITA!!!
    '86 Subaru BRAT
    Feb 27 2005
    North Wales, PA
    I did it all by myself. I usually leave all the top bolts on but slightly loose so the shock assembly stays up but can still move around. Are the sway links completely off? you can stick a screw driver in it or a bolt alignment tool in the lower strut mounting hole and use it as leverage to lift it over.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    i can do both fronts in under an hour at this point =)
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Nov 24 2005
    Native Appalachia
    Sway link on passenger disconnected, drivers completely reassembled-but wheel is still off the ground.
    '86 Subaru BRAT
    Jan 29 2007
    08 S4 00 S4
    MD
    AND the 2 13mm nuts are off and you still can't pop that thing out? You should have plenty of room to pull the shock UP and clear the lower control arm and drive shaft at this point..
    Feb 27 2005
    North Wales, PA
    just cut the end off...lol
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by mholme View Post
    leaving those nuts and bolts on will actually help. it keeps the strut supported up. I leave the 16mm control arm mount bolts tight and the 13's slightly loose. you could release the pinch bolt......if its not seized.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Poopie View Post
    Why would you want the shock supported up if you are trying to take it out? Removing all those upper nuts and bolts allows you the room to pull up on the shock and free it. There should be no need to remove the pinch bolt if you take out all the 17 mm bolts and the 13mm nuts. That's the work around for a seized pinched bolt.
    Nov 24 2005
    Native Appalachia
    I really don't want to mess with that pinch bolt.
    And...yes..I actually considered taking the cut-off wheel to the bottom of the shock!
    '86 Subaru BRAT
    Feb 27 2005
    North Wales, PA
    because you're not gaining any space by removing those bolts. If you remove those 16mm bolts and pull the control arm mount down, you are compressing the spring downwards. leaving those bolts on keeps the strut assembly supported up. With the 13s loose you still have plenty of side to side wiggle to get the lower mount up and over. If you can't get it just wait for a buddy to help or just take a long break. Usually when you come back to it, it is easier.
    Jan 29 2007
    08 S4 00 S4
    MD
    I gotta disagree from my own experience. You still get the side to side movement when you remove all the upper bolts/nuts. You can push down on the lower control arm, once all those bolts are out, the whole housing flops kind of sideways, giving you room to pull up and it will come out over the control arm. I had to do this when I couldn't get my pinch bolts out.
    Feb 27 2005
    North Wales, PA
    well we all have our methods. I never had an issue with getting the struts off sport or non sport. I've done about 7 installs on b5s with out a problem using the 2 upper bolt method.
    Nov 24 2005
    Native Appalachia
    I see both points, and really appreciate the input!
    Much more help here than rennlist and some of the other
    boards I frequent.
    The drivers side, with the 2 13s free there was
    plenty of room to get the shock over the lower
    control arm(with the wheel turned). Very odd
    that the passenger side is putting up such a fight.
    '86 Subaru BRAT
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    I just disconnected the sway bar so it releaves pressure and then put a pry bar underneath and you can pop the strut right out, pretty simple once you do the first one.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Nov 06 2006
    garage ornaments
    southeastern pa
    i use the 2 upper bolt method
    leave two top bolts in
    remove lower bolt
    get large metal bar wedge between subframe and lower control arm
    then get someone to stand on, or you can kneel on the bar, pull the bottom of the strut towards you, and then over the control arm
    -Nic
    My Car
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yeah i removed the tw 13mm from the top, the 1 18mm from the bottom and the sway linkm and the 2 upper control arms, then lifted the shock up with my left hand, pulled the hub/caliper down at to the right with my right hand and just slid the lower shock mount over the front lower control arm.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    I would undo the 18mm on the inner part of the front arm and drop that down out of the way, the shock will fly off then.
    I recon mine must be velcro'd in as they are on and off in mins now
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2024 SQ8 E-Tron, 2019 RS5
    LI, NY
    Yeah what he said.......push down on the whole assembly and pull it out. Taking them out should take no more than 30 mins after the car is up and wheels are off. Oh and please use some good spring compressors
