Page 1 of 5 123 ... LastLast
Results 1 to 40 of 189
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Who's running REVO stage III w/ 550cc injectors
    If so, are you running a stock MAF or an upgraded one? Also, are the fuel trims better?
    Trying to see if an upgrade is worth it.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Active Member Two Rings voypa's Avatar
    Oct 15 2007
    New Jersey
    Re: Who's running REVO stage III w/ 550cc injectors
    I'm running 550cc injectors with the Revo GTRS file. I'm running it with a stock MAF too.
    REVO Powered 71r
    BetaAlphaTau Member # 24
    Feb 17 2005
    Sarasota, FL
    550's, 3" MAF, fuel trims are -6% (this is with the 430/stock MAF file)
    Sep 20 2006
    MD
    OK, so that should allow more boost and/or timing. Well, if the program allows the 550's to stretch their legs. Question is....does it?
    Quote Originally Posted by A4ringedONE8T View Post
    Feb 17 2005
    Sarasota, FL
    Well Im running T6, 27psi on 93 and meth. My idle A/F sucks, way rich, around 12.0, but as soon as there is load on the car it comes up to a perfect 14.7
    Sep 20 2006
    MD
    Any ideas on what's causing that. Hell, are you even running a MAF these days??
    Feb 17 2005
    Sarasota, FL
    Yea I still have the MAF in, always have. Helps tremendously with idle stabilization (and keeps the ESP light off )
    I also still get a MAF upper limit exceeded code and the highest reading Ive seen with the larger MAF is 210 g/s, explain that one. The ECU is obviously seeing something different than what it should, so not sure, guessing its because of the MAF/Injector ratio
    FWIW, idle A/F stays the same with the MAF unplugged as well so I guess that would make it the injectors? The ECU can pull away enough fuel under load to keep the A/F correct but it cant pull enough at idle therefore it runs rich??
    Sep 20 2006
    MD
    Which 550s are you running? Let me guess, genesis? Maybe the atomization is not that great. Who knows.
    Jun 30 2007
    Raleigh, NC
    so who knows where i can still get the old revo3 file?
    i've already got my 430's
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You can still run your 430s off it I'm pretty sure.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by dirtybrd View Post
    what kind of effects do you think i'd see with that? i dont want the car to try and over-exert my injectors thinking that they're bigger than they really are. im gonna talk to a few of the local revo dealers and see if i can still get my hands on the old tune.
    The Awesome™
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You mean 440s? As in Delphi...
    -Doug
    Feb 17 2005
    Sarasota, FL
    Genesis 430's
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Genesis 430's
    No. I could have sworn I sold him my Delphi 440s. Either that or my memory is turning to shit as I get closer to 30.
    -Doug
    Jun 30 2007
    Raleigh, NC
    you did -- its my memory that sucks.
    either way the idea is the same. 430 vs 440 is hardly a difference when comparing either to a 550 -- im just trying to figure out if it's gonna be alright to run those injectors should i get stuck with the new file.
    The Awesome™
    Mar 21 2006
    Lakeland, FL.
    The old file will still be available.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Ahh I thought you were mentioning what the old file worked with, ignore my comment then
    Saint Cloud, Fl
    Shawn, question for you. Im running 440's on a 550cc file, could this be why car is running insanely rich ?
    instagram ------------> low_enforcement
    Mar 21 2006
    Lakeland, FL.
    The ECU could adjust, but it would be hard on the injectors. I said hard on!
    I'm back bitches!
    Saint Cloud, Fl
    Im debating if I should just get 550's
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by 7speed View Post
    440's on a 550 file would make it run lean if anything
    Oct 15 2007
    New Jersey
    you can run the 440s/430s with the 550 file, you just cant really get on it in the higher rpm ranges. my suggestion would just be to get 550s, thats what i did. i have 430s for sale if anyone wants to buy them though.
    REVO Powered 71r
    Saint Cloud, Fl
    I would say that it's rich(although I have not vag'd my car). When I start the car I get like a wet black sut, that Im assuming is unburned fuel
    Sep 20 2006
    MD
    OK, anyone know what the cost is to upgrade to 550 file from the 430/440 file??
    Oct 15 2007
    New Jersey
    the 440s run lean up top on the 550 file
    REVO Powered 71r
    Saint Cloud, Fl
    Quote Originally Posted by RLB6 View Post
    good question
    Veteran Member Three Rings youngspeed's Avatar
    Jan 15 2005
    RS4 Avant, A4 1.8TQM Avant 05, EVO X 08
    Spot marked X
    Revo 550 file, with genesis 550cc injectors. T6/B9. Blitz EBC. The 550 map is super smooth and has much better high end performance. To top it off, the fuel consumption is just slightly more.
    SQ5 B8 white
    REVO STG 1+ SINGLE PULLEY,APR CPS, APR 3.0T CARBON FIBER INTAKE, 034 THROTTLE BODY SILICON HOSE, 034 REAR ARB, 034 TRANSMISSION AND DIFF MOUNTS, KW V3 COILOVERS, AP RACING BBK, LEYO V1 PADDLE SHIFTERS.
    PAST RIDES - RS4 B7 MISANO RED. GIAC TUNED, MILLTEK.y
    2015 SUBARU WRX STI, ECUTEK TUNED.
    EVO X. ECUTEK, HKS EVERYTHING
    GTRS BT A4 1.8T TQM UNITRONIC TUNED
    A6 C5
    INTEGRA GSR
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Have you checked to see what your A/F is? That's more accurate then your nose and a visual on your exhaust tip.
    -Doug
    Saint Cloud, Fl
    no, I dont a have VAG-COM yet, I need hurry up and fork over the money
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    If you have the 550 file then get the 550 injectors. Your car will run much better on injectors that it was designed to work with rather then ones that are about 25% too small... not good.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    iirc, the ECU does have a tolerance of up to 25%. you're running a gt28r arent you? if so, i HIGHLY doubt that you're maxing out the 440's on that
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Saint Cloud, Fl
    yah a 28r
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I'm running the Genesis 550s with a 3" MAF with the REVO 430 file and it works fine.
    New injectors idle great compared to the Siemens 580cc I had before.
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    So is it worth the upgrade from the 430 file. Cost?
    ReVO BT and a bunch of other stuff
    Sep 20 2006
    MD
    OK, upgrading to the 550 file is actually FREE. However, your REVO dealer may charge like a half hour labor to do the reflash. Also, the 430/440 injectors will run on the 550 file but will run severely lean on topend in high boost situations. The upgrade is definitely worth it because the idle will be smoother and you'll have alot more headroom on top end to turn up the boost and/or increase timing.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Are [most of] you guys still running the stock MAF housing with the REVO files?
    I'm on a 3inch MAF housing and 630s but not REVO software.
    -Doug
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I used a hole saw and cut out the stock airbox so it would receive the 3" VR6 maf housing (using 1.8T sensor). Worked well. 550cc genesis and 550cc 8500rpm revo file of course... Guess we'll see how it runs in a couple weeks here...
    Sep 20 2006
    MD
    I am and the 550 file from REVO is designed to work with the stock MAF or an upgraded 3" MAF.
    Sep 20 2006
    MD
    Are you still using an Elim turbo with your stroked motor or have you upgraded.
    Quote Originally Posted by CO AVANT View Post
    Feb 12 2004
    Everywhere
    No I upgraded. Actually sold all my elim stuff to Condo, and he's already upgrading lol... I now have all APR 3+ hardware and am using a GT2871R .64a/r T25 turbo. Mani, hotside, and TP are thermal/ceramic coated 1800deg.
    I would have built this car differently if I were at sea level. I am trying to keep exhaust velocity high with this setup...
