Results 1 to 3 of 3
    Junior Member Two Rings
    Jun 30 2007
    Greenville
    Finally logged engine measure blocks but need help
    measured and logged engine blocks? *shrug*
    Unfortunately I don't really know how to interpret them, nor did I know about setting markers. Hopefully someone won't mind pilfering through this 90KB DB or giving me advice as to which blocks to measure next time. I had a few codes thrown last year but since then they have disappeared. I guess I just want to know if the car is running correctly, or if it's even possible to tell from these logs.
    http://www.audizine.com/forum/showthread.php?t=166446 - old problems
    http://elusivity.com/LOG-01-111-115-003.CSV - comma seperated
    http://elusivity.com/LOG-01-111-115-003.htm - web
    thanks
    Feb 17 2004
    Sterling, VA
    Re: Finally logged engine measure blocks but need help
    I reviewed your log file and it looks ok.
    You are making about 8-9Psi of boost (stock programming) and the MAF is showing a peak of 227g/s at 6320 rpm. This is very typical operation for a stock A6 2.7T.
    I compared this to my car when running the stock K03s and it matched almost perfectly.
    So since you last batch of CELs last year, you have not received any more of them?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jun 30 2007
    Greenville
    Thanks for the response Daft. The codes I was throwing back in November are listed below. I'm not 100% sure that I didn't accidentally clear them the other night, but I've scanned twice since and they haven't returned. One of the main issues I still have is on a full 18.5gal tank I see...
    135 Miles until Empty
    5.0MPG avg
    20 MPH avg
    When hooked up to measure the block that gives speed, it was spot on in km/hr.
    Address 01: Engine
    Controller: 4B0 907 551 Q
    Component: 2.7l V6/5VT 0003
    Coding: 06752
    5 Faults Found:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 35-00 - -
    16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
    P0421 - 35-10 - - - Intermittent
    17546 - Shareware Version. To Decode all DTCs
    P1138 - 35-00 - Please Register/Activate
    Readiness: 0000 0000
    On the way home today I logged different blocks and then took the car around the block logging a few instrument cluster blocks. The speed seems like it might be accurate. Whenever I hold the reset button while on the MPH display it will read correctly for a short time before falling to 20MPH. I can also reset the MPG and it will read 15-15.2 before falling to 5.0MPG and staying.
    www.elusivity.com/LOG-01-000-002-005.CSV engine
    www.elusivity.com/LOG-17-002-010-001.CSV instrum.
