Results 1 to 4 of 4
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    Anyone wh ETKA i need some help
    My laptop with etka is giving me problems.. I was putting back together my dash, specifically the glove box. When you put the glove box in there are two bolts on the radio side. The top one goes though two metal tabs then into a clip. I lost that damn clip and i need it to get the dash back together. Any help would be greatly appreciated. Thanks.
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Anyone wh ETKA i need some help
    Do you see it here?
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    http://www.vagcat.com/ i use this, its an online etka
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Queens, NYC
    Quote Originally Posted by mholme View Post
    Do you see it here?
    IT may be the same clip as #13 pictured there, ill double check that on the car asap. Thanks
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
