Thread: Weird boosting
    Apr 22 2007
    Riverbank, Ca
    Weird boosting
    So Last summer when I bought the car I was boosting around 20psi, Come winter and it slowly rolls down to 15psi. I first attributed it to my plugged cat from doing a seafoam treatment.. But now yesterday driving 200 miles I got on it a couple of times to pass people (So far im at 350miles on my tank w/ 1/4 tank left.. trying to get some good MPG readings before I install my stage 3 kit) and It runs right back up to 20psi! Keep in mind this is 5th gear @ 3krpms and my temp gauge says its 94 degrees outside.
    Now Today Its 54 degrees outside in the morning and after its warmed up I do a quick boost in 3rd gear and its at 15psi.. Warmed up for lunch, about 70 outside and its at 17psi.
    Can anyone explain this? This is a large amount of boost difference..
    Current Setup:
    k03
    FMIC (Past summer no FMIC, no difference in boost due to no MBC)
    GIAC file
    Borla exhaust, 1st muffler delete
    KNN filter w/ opened up airbox
    Baileys DV
    What are your thoughts? Freak of nature? Any logical explanation?
    It doesnt really make much difference as I am installing my APR Stage 3 setup very shortly (Just got my 2 post lift installed in the garage). I just am really confused..
    Apr 22 2007
    Riverbank, Ca
    Re: Weird boosting
    Wow no one?
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: Weird boosting
    boost leak maybe? have you tested it?
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    Re: Weird boosting
    yeah on the giac files, cooler weather gives you less boost readings, cause it's denser air. in 80+ degrees i used to jump up to like 20-22 psi on giac files, but still felt slower.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: Weird boosting
    maybe a shot in the dark but how about colder air = denser air = not as much boost, but same performance due to lower iat's. its completly normal and im assuming you didnt feel a performance dif?
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
