I know that newer modules will work older head units, but vice-versa is less clear. Which head unit do you have? Do you have tire pressure monitoring? Check the sticky thread at the top of the forum, that will tell you the correct part number. The other difference to worry about is whether your car's antenna has one or two satellite leads. Older ones have two leads, newer ones have one, so you might need to get an adapter if it doesn't match up right.
Figure out what you need and check on eBay. There are lots for sale over there. Search for "VW" as well as Audi, since they use the same module in both (and VW people seem to want less for theirs than Audi folks do).
