Results 1 to 37 of 37
    Established Member Two Rings hiphoppopotamus's Avatar
    Apr 12 2008
    2008 A4 B7 Avant; 2009 MKV GTI; 2006 A4 B6
    Carlsbad, CA
    Question buying a b6 3.0; maintence/warranty concerns?
    im very close to purchasing my first audi...
    im looking at a pretty interesting combination:
    its a 04' silver USP 3.0 6-speed manual...
    ill be buying this car with 39k miles for ~$20k, but heres the catch...
    its on a mitsubishi lot.
    im starting in at lawschool on the east coast this fall, and i wont be able to handle any big maintence/repair issues if they arise, financially.
    this not being a a turbo car, and a NA v6, what are some major issues or concerns i should be aware of or consider after this amount of mileage...is extended warranty worth getting?
    *buying this car used, warranty is my question. mistubishi offers an extended warranty...but how would this work? i havent looked into it, but would that even be an option? can i somehow get an extended thru audi? should i be worried about even getting an extended warranty for this car? thought/ideas on this please...
    ill be purchsing it from a bayarea, CA dealership, and driving it cross country with my best friend this summer, and other then that, it will get me around upstate NY...
    i feel the 3.0 quattro, with what ill be doing with the car and where ill be located, is a good idea. im not going to mod it all that much. adam and i have a few simple, mellow things we plan to do, but the car, especially performance wise, wont be touched, hence the 3.0 motor being good for me.
    i wanted a manual, and love the ultrasport body/goodies, so i think this is a PERFECT cadidate...im just concerned with maintence, warranty, and buying it from a mitsu lot.
    thanks for the help, and plan to be around the boards often...
    -k
    REVO Stage II :: Neuspeed Catback 70mm :: 034 HFC :: Neuspeed Sport Springs :: H&R Spacers 15f/20r :: OEM+
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    Re: buying a b6 3.0; maintence/warranty concerns?
    ...thats my boy
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    not sure what the point of the mitsu. dealer warranty if you are going to be across the country from where you bought it. If you could get the actual audi warranty than it would probably be worthwhile.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Quote Originally Posted by cjonesgo View Post
    thats what hes asking dude...is that possible?
    plus...getting and extended warranty with a dealer, doesnt mean you take it to THAT dealer only does it?
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    Kev....I would try and get the VIN and contact Audi to see if there is any factory warranty left....Normally, when the factory warranty is running out, the manufacturer will contact you and ask if you want to buy an extended warranty.....The warranty that Mitsu is offering is more than likely a 3rd party warranty that can be used pretty much anywhere....And within that, you will have a few different options on how much you want it to cover.....
    As for reliability on the 3.0, the only problem I have had ***knock on wood*** was a small coolant leak which is normal. But then again, my car is still pretty low mileage at under 50K....
    - Justin
    need rotors?...adam's rotors
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by norcatalyst126 View Post
    - Justin
    +1
    bewm
    May 22 2007
    oakland ca
    Not all 3rd party warranties are created equal. Many of them have VERY restricted policies on where you can take your car, what is covered etc. Read ALL of the fine print.
    The OP is going to just have to research the warranty that is being offered and find out if it is worthwhile. Or as mentioned by norcatalyst, contact audi to find out if he can warranty through them.
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    I just bought an 03 1.8t Avant with 39k and the Toyota dealer wanted $3k for 3 years 36k miles for a third party warranty.
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Veteran Member Four Rings Onese1f's Avatar
    Jul 22 2007
    01 A6 2.8, 03 3.2 CL
    Sunrise/Orlando, Florida
    To the OP:
    Coilpacks may blow, you're going to want to buy extras. They aren't too expensive and take like 5-10 minutes to change out.
    Timing Belt/Water-pump: You're gonna want to do these at around 60-70k miles. If you own the car for that long.
    People have talked about oil-leaks but they were isolated incidents so I can't really speak about those.
    I was lost, and I'm still lost...but I feel so much better
    Galt, CA
    Quote Originally Posted by Onese1f View Post
    To the OP:
    CP's going bad on a 3.0???......Has anyone else had this issue???....I didn't know it was an issue with the 3.0's.....
    Apr 12 2008
    Carlsbad, CA
    Quote Originally Posted by sailor View Post
    does this seem to be standard for a 3rd party warranty? and does anybody have an idea about how much the audi extended warranty (I believe 100k/6yr) costs?
    thanks for all the feedback.
    Jul 22 2007
    Yep believe it or not my friend actually had an issue with his! I was just as as you are.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    It does happen. But with less heat from no turbos, it's more rare. Keeping spares in the trunk is still recommended though.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by skeeball View Post
    Note to self... Thanks
    Dec 06 2007
    get an Audi extended warranty only, if u get a third party warranty with limited crap ur gonna end up taking it to some place where some dufuses who've never seen an Audi will expirement on ur car, and an extended warranty costs more after every year of ownership and it is 7yrs/100k from the date of purchase by the first owner, when the car had under 10 miles if the car is on its last year ur gonna get 3yrs/100k warranty! 3.0's are pretty reliable, but have it inspected before u go cross country, these things are cash cows so do all preventive measures possible!GL!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I looked at service history and it had pretty much replaced all coil packs, plus I replaced one myself.
    Apr 12 2008
    Carlsbad, CA
    What do you guys think about this? His asking price is slightly above 25K, which is a good 5K over the KBB value for Private Party in Excellent condition...he is well firm on his price, as he claims to owe 27K on the vehicle still...he also claims the rarity of the USP w/ low miles as a reason to stay firm on his price as well...
    http://sfbay.craigslist.org/nby/car/639672965.html
    39,xxx miles
    6 speed manual
    Quattro
    ULTRASPORT, this is a very rare package, originally added $3000 to the sticker. Includes: lowered/tighter suspension, S4 18” wheels, metallic interior trim, Xenon headlamps, S4 body work
    BOSE, 6 CD changer, XM Sat with subscription paid thru 5/16/2008
    They now have an Ipod adapter avail for about $150 that you could add at the dealer
    Power driver seat
    Heated front seats (they get really hot!)
    CERTIFIED this means maintenance included. 6 year, 100,000 mile warranty good until April 2010. The Certified warranty covers everything (fully transferable).
    Conti sport tires, less than two years old, 17,000 miles on them
    Had her “Chipped”, this means:
    Increased fuel economy: road trips I’ll see approx 33 MPG, mixed driving I’ll see approx 28 MPG. Seriously, that’s better than most of the Hybrids out there now…
    Increased horsepower, faster 0-60 (right @ 6 seconds).
    Established Member Two Rings colson's Avatar
    Nov 28 2006
    2005 s4 White/Black 6sp manual
    San Francisco, CA
    haha he will never get that much for that...it's a 1.8t and stock except for the chip. its obviously not worth that much,
    i would go with the 3.0...i love mine. i have a 2002 3.0 6 sp. quattro and i have had no problems with it! The fan in the front was set on high so i had to get the control module replaced but that was easy. other than that nothing.
    good luck with your decision
    05 s4 white/6sp manual.
    Apr 12 2008
    Carlsbad, CA
    Quote Originally Posted by colson View Post
    thanks dude! actually, the 3.0 was bought, which is a bummer but not the biggest deal in the world...
    i definitely agree about dude not getting what he is asking...way too high...he acts like KBB doesn't apply to USP's, even though the price I'm quoting included USP. he just owes a ton of cash and is too stubborn to see that he's not going to get what he's asking for...at least not from the minimally informed buyer.
    Apr 12 2008
    Carlsbad, CA
    Could somebody explain real quick exactly what an Audi Certified Pre-Owned vehicle is? Is the 6yr/100k extended warranty a part of this? How comprehensive is the warranty? What exactly does it cover...?
    thanks to everybody who responds...input from people who really know their shit is invaluable.
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 09 2004
    east bay, CA
    get the 3.0. thats super rare.
    err, not that 3.0, but get a 3.0 manual. they are awesome!
    when you are out here, maybe take a look at mine, i've tossed the idea around, of selling her.
    - Benny
    Apr 12 2008
    Carlsbad, CA
    that 3.0 is a manual...but it's sold, unfortunately. i'd take a look at yours for sure. any pics? specs?
    Galt, CA
    Audi's CPO Warranty covers the car for up to 2 years or 100,000 miles (total on the odometer).....also, there is a $50 deductible.....my warranty is up Aug. 1st and i'm dreading it.....
    i want to talk to dude further kev...
    i want to be clear, as you stated, that KBB DOES in fact account for this UBER-FUCKING-RARE pkg. of a USP
    ...and this thread so maybe he gets motivated to stop playing games and get a sale. in the hole or not, i think hed rather sell it then sit on it...paying monthlys or selling it for a decent price, it really makes no difference in the end
    *edit: and this cats in napa...its not that easy for me to peep it. im bummed the 3.0 sold...that would have been sweet. well see what happens...
    ANYONE KNOW OF A MANUAL USP FOR SALE? low miles...either motor
    Galt, CA
    Quote Originally Posted by Adam@SPP View Post
    Yo....I was checking audiusa.com and they have quite a few USP's for sale....you have to look at each one tho to see if its USP.....What's your budget Kev?....Perk of getting through Audi is you will definately get the CPO warranty.....
    Mar 11 2008
    B7RS4 & e46Ms
    Definitely sounds high... To give you a comparison, I bought mine at the beginning of march 08:
    17k miles, 3.0 USP MT6 with zero blemishes anywhere, brand new brakes/fluid, new tires, fuel filter, blah blah..., and every option exc nav, rear sunshade, and rear heated seats. It's a CPO car under warantee till 2010/100k. I paid pretty much top $ for it at 25k from an audi dealer... So I wouldn't think of paying more then that for anything less...
    The other cars I looked at were all 1.8s, and all in the low 20k range. A week or two after I bought mine, I saw 6 or 7 more for sale in the socal area. Just be patient and the right deal will present itself to you.
    Apr 12 2008
    Carlsbad, CA
    can't go above 20k, and the CPO warranty is a must...so that's pretty much what i'm working with...thanks for all the input and advice dude...can't wait till this summer for us all to get together!
    Apr 12 2008
    Carlsbad, CA
    thanks dude! there is definitely no reason for me to be impatient with this...i definitely have a bit of time to work with here, so I have no plan on settling for anything less than what i'm looking for.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    39K is pretty low for the 3.0. don't buy the warranty at Mitsubichi, buy the extended warranty from Audi! read carefully on what it covers though, does it cover suspension components and stuff.
    3.0 is reliable as long as you take care of it, be prepared to pay more each time you take your car into a shop for oil change, tune up, timing belt and such.
    where are you going on the east coast?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    you guys! READ...the 3.0 isnt an option any more...it sold over the weekend. we found out monday its no longer available...
    ...moving on
    Mar 09 2004
    east bay, CA
    Quote Originally Posted by hiphoppopotamus View Post
    03 3.0QMS
    moonroof, bose, premium pack. blk leather, dolphin gray. heated seats, the usual.
    mods: KW VII, h-sport sways and a custom magnaflow exh. it has different wheels on it now. black iforged aeros. wett chip, blue tint. 33kmiles. its been maintained under the audi maint until recently. i did the first non dealer oil change about 2 months ago. I'm the second owner, and its only had either GC or Total ineo MC3 oil in it.
    - Benny
    Veteran Member Three Rings sadpandas's Avatar
    Oct 05 2006
    b6 a4 grocery warrior
    High Atop The Eagle Rock
    I read it has been sold but there were other topics brought up that we can address :):
    It's rare but it does happen; it happened to me a couple of years ago. I did buy extras but haven't had to use them yet. Knock the wood. Also, find out the 3rd party warranty company and have the local dealer call them to see if they will send them their policy. If your service advisor is super nice he will go over it with you. super super nice :).
    panda
    b6 a4 avant-blk/blk
    2010 Kenny Anderson 'Bar' series, Royal O.G. trucks, 54mm Girl Streamline wheels
    Apr 12 2008
    Carlsbad, CA
    thanks for the feedback guys...
    so justin, or anybody else who knows....you mentioned getting the VIN and calling audi to see if they could offer an extended warranty...who exactly do you call when you call the ominous audi?
    Apr 12 2008
    Carlsbad, CA
    Quote Originally Posted by 3ohAvant View Post
    03 3.0QMS
    shit's looking ill bud...not really in the market for an avant, but i like it...thanks for the post.
    Mar 09 2004
    east bay, CA
    oh whoa. thats SOO weird. i swore i saw you mention avant when you were talking about that USP. my bad.
    - Benny
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    I just can recommend the 3.0. Got it about 2 month ago and still love it. I love the manual and the color with the tinted windows.
    Fiend of ine is a Audi mechanic in Germany and recommended the 3.0 over the S$ 2.7T what was my alternative. Good luck.
    Are you planning on tranfering the car to Paris one day???
    2002 A4 3.0 Quattro Manual
