Results 1 to 15 of 15
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    Quieting down 3 inch exhaust
    gt28r 3 inch downpipe 3 inch pipe to milltek muffler. The sound is very nice, the drone is really bad. (you can't take the car out for a half hour without getting a headache)
    What to do?
    Add a mid-muffler? Add a resonator? Add a HFC?
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Dec 12 2006
    Ottawa, ON, Canada
    Re: Quieting down 3 inch exhaust
    add a mid muffler. I put a Thermal R&D exhaust on my car which is known for the drone, I personally think the drone is due to the 3" midpipe ... at low rpm rates there's not enough flow so the air kinda gets backed up and does not flow properly.
    I found that adding a 18" resonator between the downpipe and right before you get to the Y split really helped. It doesn't completely get rid of the drone, but it does make it much much better to the point where it's not really an issue.
    I'll be adding a HFC at some point, so we'll see if that changes anything, if anything I would think that should lower the RPM at which it drones, if my theory on why the drone happens is true, since you'll get a bit better flow so the noise point will move lower down.
    Hope that helps.
    http://www.magnaflow.com/02product/s...e=main&id=6837
    If I remember right, this is what I used.
    2003 A4 Avant 1.8T, 5psd, Atlas Grey, GIAC FXK03, TT225, Injectors, Thermal R&D, stock suspension , winter tires.
    Dec 12 2006
    Ottawa, ON, Canada
    oops, sorry, I didn't realize you were on a B5 ... so ignore my comment on the Y split since you don't have that. I think my comments still apply.
    Jan 22 2007
    NNJ
    The muffler is 2.75 the piping is 3 inch. Think the small change in size would cause such bad drone?
    Going to try either mid muffler or resonator
    2012 Cayman S Track
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    mufflers muffle and resonators get rid of drone.
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Jan 22 2007
    NNJ
    went with vibrant "ultra quiet" 14 inch resonator. It sounds the same $175 later....
    2012 Cayman S Track
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Also - Make sure your hangers are working properly. I had an exhaust put together and it had bad drone. I replaced the muffler to quiet things down - the whole thing is non-resonated. The new muffler quieted things down a bit and changed the sound from raspy to a little more sophisticated/metallic, but while I had it suspended with some wire before I could properly fasten it, it still had the drone. When I put in a new hanger and tightened the mounting up, the drone was largely reduced - even without the resonator. It seems that if the exhaust is just hanging and barely supported by the hangers, there may be more resonation/drone, where if it is more securely fastened, the hangers absorb the vibration and remove the drone.
    At least it did with my car...
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    I had the same problem you had with the droning. I have a 3" custom exhaust from the turbo back. I have a HFC right after the turbo. to quiet the droning i installed a 18" or 24" dynomax race muffler in front of the muffler that was already there. It almost completely eliminated the drone. I bought mine from summitracing.com here is the link http://store.summitracing.com/partdetail.asp?autofilter=1&part=WLK%2D24219&N=700 +1003+115&autoview=sku[/URL]
    It was only $45.00 bucks too!
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    2 resonators for me= almost no drone.
    2.5" turbo back
    T28 turbo
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    mmm without a cat - your car will drone no matter what - trust
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by aytheory View Post
    very true.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    3inch from turbo to flex pipe to cherry bomb 18" to magnaflow muffler. Sounds fuckin awsome. Almost no drone!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Suck it up, be a man and deal with the drone!:)
    Jan 22 2007
    NNJ
    I am actually getting used to it sounds great at WOT
    2012 Cayman S Track
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    i have gtrs, 3" tp and 2.5" exhaust.... i believe it has a resonator.
    0 DRONE.
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
