Results 1 to 9 of 9
    Registered Member Two Rings
    Mar 14 2008
    OKC,OK
    smoke coming from right side of motor
    First off I bought this car two weeks ago have put 1500 miles on it already I didn't drive the car for two days and drove it this weekend for a mile. Parked and saw smoke coming out of the right front wheel. I open the hood and way down in between the airbox and the right engine cover smoke was coming out. It seems very hot for such short distance towards the back of the motor and it smelt like oil. I'm wondering if I have a small oil leak and it's leaking on the exhaust/manifold or something and buning off. Since I didn't drive it for a few day more was able to drip and more to burn off??? I don't know. Could you guys maybe help me. I'm coming from a 328I E46 BMW and the engine compartment looks a lot harder on this S4. It's a 2000 Nogaro Blue with 78k I paid 10k for it. Thanks in adance and you guys are awesome so far!!
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: smoke coming from right side of motor
    I had the same problem. I replaced my valve cover gaskets and no more problem.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    also check your mechanical cam timing adjuster gasket. both mine were leaking and i was getting little wispes of smoke out the rightside tire
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    id bet anything its your valve cover gasket. I just had both of mine done along with both cam adjuster seals as well... all under warranty
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Veteran Member Three Rings Auburnsky1287's Avatar
    Jan 06 2008
    Orlando
    Valve cover gasket lol, happened to me too. It would've cost about 900 if it wasn't under warranty for me
    2001 Audi S4
    Vast Tuned Stage 3
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Quote Originally Posted by Auburnsky1287 View Post
    $900 to replace two sets of gaskets? Hmmm...
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Jan 06 2008
    Orlando
    Quote Originally Posted by Elitedrumr View Post
    and the cam adjuster seals.... I didn't pay a cent thank god, but thats what Classic Audi was gonna charge me
    2001 Audi S4
    Vast Tuned Stage 3
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    ^ second to that... had the same experience.. same etiologic factors... same solution
    -cam seals
    -tensioner gaskets
    parts required :
    2 078-198-025 GASKET SET
    2 058-198-217 GASKET SET
    2 078-103-113-E COVER
    4 026-103-085-D SEAL
    for the next DIY'er
    btw... need to take your avatar.. and x2 it ... need another snail on there =)
    Mar 14 2008
    OKC,OK
    thanks guys....!!! I replace the exhaust man. gaskets on the BMW and the mech "BOOK" said it take 14hrs to replace that ways the dealer can charge you 14hrs of labor even though it might take them 2hrs to do it. I guess I'm going to attack this after a little while. I'll just watch the oil for a while. I'm trying to save up $2500 for this bronco that has a brand new motor so I can depend on that as a daily driver while I tackle the AUDI
