Results 1 to 14 of 14
Thread: TB Worth it?
    Veteran Member Four Rings Onese1f's Avatar
    Jul 22 2007
    01 A6 2.8, 03 3.2 CL
    Sunrise/Orlando, Florida
    TB Worth it?
    I was wondering if getting a full tb exhaust on a 180 fwd would really be worth all the money spent. I'm planning on going Revo Stg2 but considering the minimal gains I get in buying a whole exhaust system wouldn't it make more sense to just get a newer tp? I understand the concept of "it couldn't hurt", but I just don't see paying the money for a 1/2'' or less of extra piping diameter. As far as sound goes I don't see why you couldn't just go magnaflow muffler with stock exhaust and upgraded tp.
    Thoughts?
    I was lost, and I'm still lost...but I feel so much better
    Mar 28 2008
    Westland, Mich
    Re: TB Worth it?
    I have a cat back borla system for a fwd 180 if your interested $350.00 plus shipping.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Re: TB Worth it?
    Just go custom.
    ÖMGHI2Ü
    Photography
    Registered Member Two Rings NeonOngeHatGuy's Avatar
    Jan 19 2007
    2000 Audi TT 180 FWD
    Greensboro, NC / Auburn, AL
    Re: TB Worth it?
    ^ its what im doing....trying to work that APR turbo-back exhaust for a 225 onto my 180
    2000 180 FWD Amulet Red TT
    Remus Exhaust :: OZ Chrono HT 18's :: HKS SSQV :: Injen CAI :: APR Tuned
    OEM AUDI TT WHEELS FOR SALE CRAZY CHEAP!!
    _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    http://s243.photobucket.com/albums/ff274/Slickhunter6/
    Jul 22 2007
    Re: TB Worth it?
    Custom is looking better and better.
    Established Member Two Rings JettaRedII's Avatar
    Oct 05 2006
    2004 TT225, 2000 A4Q, 1999 A4Q
    Re: TB Worth it?
    Quote Originally Posted by NeonOngeHatGuy View Post
    Dude, that wont fit unless you're putting a K04 on. Is your 180 a quattro?
    Actually, for the 180 (because it is like the GTI I had), the GHL downpipe is going to give you most of your gains. A catback from there is going to give you more noise, some very high end power, but at the cost of low end torque. You may not like it.
    (Wait while I put my asbestos suit on. But that's the stinkin truth!)
    2004 Audi TT 225Q GIAC, Forge 007P, Neuspeed 19mm RSB, BoostMachine, Haldex Blue, DevilsOwn W/M Injection
    2002 VW GTI 337 Revo, FMIC, TT225 MAF & Injectors
    1999.5 Audi A4 1.8TQ GIAC, 710N
    2001 Audi A4 1.8TQ DEAD
    2000 Supercharged JettaRed DEAD
    Oct 05 2006
    Re: TB Worth it?
    Quote Originally Posted by Onese1f View Post
    Thoughts?
    A downpipe, especially on a 180, is almost always worth it. Should be the second mod after a chip. If the 180 uses the same configuration at VWs (GTI, Jetta), it's like a soda straw compared to a paper towel tube. You'll notice big gains even with the stock exhaust. Then you can add the TDI mid-pipe to eliminate the mid-muffler if you want a little more sound and power.
    Jan 19 2007
    Re: TB Worth it?
    I think i got it worked out...3" dp from 42DD and then i found a place where you can buy everything from the dp back online for the same exhaust set up
    Established Member Two Rings Euroluv's Avatar
    Nov 16 2006
    Re: TB Worth it?
    should check out eurojets 3in cat back, a 3in d/p for the 225 is in the works will be fitted this week
    "when things are good, go racing. When things arent so good, go racing."
    "M3 drivers have no friends" -Jeremy Clarkson
    Jul 22 2007
    Re: TB Worth it?
    Sucks that I don't have a 225 ^ or I'd be all over that.
    I think the DP with stock exhaust setup would be good for a while, do you think it would bottleneck drastically? That is, until the rest of the exhaust gets put on?
    Oct 05 2006
    Re: TB Worth it?
    I had the 2.5" downpipe on my GTI with the stock exhaust. Then later added a matching 2.5" catback, all from GHL. I honestly don't remember any significant performance difference between the stock with TDI mid-pipe and the 2.5" catback, other than the noise. The big difference was going from stock to larger downpipe.
    If you think about it, gases shrink in volume as they cool. So the further away from the cat, the less volume you need. You should be fine with the stock exhaust.
    Jul 22 2007
    Re: TB Worth it?
    Put an order in for 42DD 3'' DP and 2.5'' test pipe and hooking that up to stock exhaust till someone comes out with a catback thats worthwhile for the fwd 180. Btw Clipse the Greddy G2s has a whack piping diameter =(
    I was wondering though..worth getting a test pipe or hfc?
    I live in FL so I don't need to worry about emissions, and the smell doesn't bother me although I've heard you sacrifice a few mpgs in the process, but the amount is negligible.
    I understand that a test pipe almost ALWAYS has the upper hand over a stock cat (unless you drive an S2k) but since the cat is considered "high-flow" wouldn't that just be the same thing? I think it just might be the same thing in terms of performance, with the added bonus of passing emissions no?
    Edit: just read about how hfc's are known to not be able to withstand temps and have about 1/2 the life of our stock cats? Can anyone confirm this?
    Kinda of glad I went with test pipe anyways though...Just wondering if hfc would have been better/same thing/worse.
    Feb 11 2008
    Re: TB Worth it?
    ^ you better get wayne's angled machined block to avoid the CEL with the testpipe. i know techtonics tuning has their FWD 180 TT exhaust using borla muffler's. you myte want to check that out.
    Jul 22 2007
    Re: TB Worth it?
    Quote Originally Posted by .clipse View Post
    Well thats a good idea but I'm not worried about throwing a CEL, I'm getting the exhaust stuff done before I chip so no worries.
    I've checked out the exhaust they have I've seen the link from perf-cafe and frankly $300 for proven gains vs $600 for minimal gains, doesn't seem high on the priority list. Taking care of the Dp/Tp, chip, dv, gauge, and THEN I'll consider just adding on an exhaust before I get my rsb and bbk.
    I just think the $600 can be used for something waaayyy better. And the TT will sound nasty enough with dp/tp.
