Results 1 to 9 of 9
    New Member Three Rings
    Feb 05 2006
    A4 2.0T Quattro
    eibach prostreet kit on c/os
    i have stassis street sport kit now and wanted to add eibach prokit sprints to it.. would this make my car handle better? main reason is the front and rear ride heights are different if i put new sprints on it will put it where i want all the time..any info?
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Re: eibach prostreet kit on c/os
    The shape of the Koni springs is different on the lower side that goes against the adjustable perches on your stasis. Also the rear Eibachs are longer. I'm afraid it's not possible.
    Best
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Feb 05 2006
    A4 2.0T Quattro
    any other sprint combo? maybe h&r?
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Quote Originally Posted by audia420turbo View Post
    Why are you not happy with your Koni springs? In my opinion they are very good and the progressive design makes them perfect for street use. Also you can adjust the height pretty much as you like. Hope it doesn't sound like I'm telling you ;) Just wondering.
    One aspect of the eibachs that is better is the powder coating.
    Regards
    Feb 05 2006
    A4 2.0T Quattro
    cant raise the back up high enough and the back is always lower then front i dont like how they look
    Feb 15 2008
    lotsa tools
    Vienna, VA
    You can raise the back up to 26" from lip of fender to ground which is almost like the OEM sport suspension. I have 25.75 rear and 25.5 front. Look at my thread with pics called "Stasis with Conservative drop"
    Cheers
    Feb 05 2006
    A4 2.0T Quattro
    yea thats exactly how i want it is that as high as it goes? i got mine put in at euro tire in jersey and they said its too hard to match the front and rear that close my back wheels are tucked under the fender about a half inch and front are about an inch different the back..how hard is it to change the height myself?
    Feb 15 2008
    lotsa tools
    Vienna, VA
    I believe it can go 1/4" higher than mine at the rear, and as high as you want in the front.
    Euro Tire in Jersey (I don't know them) shouldn't give you that BS if they are charging you for their work. Your coilovers are fully adjustable to the height you want. If they are not capable or not willing to do a good job than it's a different story.
    About how hard it is for you to do it yourself, I would have to know what skills, will, and tools you have to tell you. Lifting the rears is not rocket science but you have to cut your provided wrench an inch and do a workaround so you won't need to disassemble the whole thing to be able to do the job. I will gladly explain it to you if you want to do it, but if I were you I would go to that shop and tell them that they should do it right.
    Bests
    Feb 05 2006
    A4 2.0T Quattro
    yea i dont know too much might be too hard for me.. any idea on how much a normal shop would cost to adjust them? and dont i need a realignment after aswell?
