Results 1 to 30 of 30
    Registered Member Two Rings my_01_S4's Avatar
    Jun 20 2007
    Silicon Valley, CA
    Coolant Loss, no smoke, not overheating (yet)
    01 S4 w/ 150k. I'm the 2nd owner but from the carfax records I know it's been maintained well (all dealership serviced) but now I'm loosing coolant. Not while driving (that I can tell) but after I come to a stop and shut off the engine. I don't see any leaks right away but after it's cooled ~ a cup can be found under the car.
    Where are the common failure points it could be coming from?
    I don't detect any sickly sweet coolant smell when driving which I expect w/ a typical coolant leak so I'm hoping this is a known error that's easy to diagnose and cure.
    TIA
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    Re: Coolant Loss, no smoke, not overheating (yet)
    secondary coolant pump is what was broken on mine when it was doing the same thing.
    -Luis
    Jun 20 2007
    Silicon Valley, CA
    Do you mean the Auxiliary Water Pump (#5 in this illustration from the Bentley manual)?
    Nov 01 2005
    S4
    VA
    i believe so
    -Luis
    Jun 20 2007
    Silicon Valley, CA
    This seems simple enough to access. Have you R&R'd it before or did you have a shop do it? IF you did it yourself, how hard was it?
    If you didn't, has anyone else done it?
    Nov 01 2005
    S4
    VA
    i just took it to audi..
    -Luis
    Registered Member Two Rings Syndromeofadown's Avatar
    Apr 09 2008
    T-Town, CA
    Pressurize the coolant system while the car is off (special tools needed!) and check for leaks. Or just man up and let the car run after beating up on it with the heater on so the thermostat is open - then look for visible leaks.
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Are you sssuuuurrre its coolant that you are finding on the ground? If you are losing a cup everytime, you should be filling your reservoir alot, are you?
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Active Member Two Rings Rican_S4's Avatar
    Mar 10 2005
    NC
    I'm going to bet it's the Afterrun Coolant Pump or a cracked reservoir. Mainly betting it's the pump.
    Mar 21 2008
    Im having the same problem they diagnosed it as the water pump which is a 900$ job but the leak i see it coming from the back of the motor and dont know if the dealerships trying to rip me off?? any ideass??
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by looseboost View Post
    A leaky after-run pump can leak from the rear. Remove engine plastic engine covers and use a flashlight to look at the valley area underneath the intake manifolds. If you see pink dried coolant, then you certain does have a leak in your after-run pump. Try an ind. shop, you may be able to find someone for ~$500 or so.
    Aug 10 2007
    Castle Rock, CO
    This is what bad afterrun looks like without the intake manifold:
    Mar 21 2008
    Very helpful i will be takeing a look at this when i get home even thow the smarties at audi decided to give me Green coolant instead of g12
    Jun 20 2007
    Silicon Valley, CA
    Thanks for those pics. I tried to look in between the cracks and crevices to see if there's any residue. None. My BIL who's a mechanic suggested I lift her and check underneath to trace back where the fluid is coming from. Will check up top again but if no luck I guess I'll have to do that. Luckily he has an 02 Passat w/ the same engine but normally aspirated so he's quite familiar with it.
    ...the smarties at audi decided to give me Green coolant instead of g12
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by my_01_S4 View Post
    About where are you seeing this puddle of coolant, underneath the front, center, right rear or left rear of the engine ? Try to be a little more specific if you can. Also, do you notice more coolant loss if you were to drive the car hard ?
    Senior Member Two Rings u7401087's Avatar
    Feb 23 2006
    Indiana
    Hi.....Tifosi
    you mention something about more coolant loss under hard driving.....
    could you talk more about this?
    Paul
    RS4 grill~custom widebody~M3 style lip~DTM Kreuz 10
    Dynaudio~Xtant~
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by u7401087 View Post
    Hi.....Tifosi
    Paul
    If this condition is also associated with mysterous misfires at idle and noticing a lot of pressure buildup when you open the cap of the coolant expansion tank. Unfortunately, these symptoms are a good indicator that you may have a head gasket leak.
    A bad head gasket seal can over-pressurize the coolant system and cause coolant loss through the over-flow valve/hose of the expansion tank. This can be easily confirmed or ruled out by using a block test kit from your local auto part store. It is a simple test but amazingly accurate.
    http://www.napaonline.com/MasterPage.../+Engine+Block
    Junior Member Two Rings
    Feb 20 2008
    florida
    the orings that seal the rear coolant pipe sometimes go bad, or perhaps even a heater core hose, look at where your evaporator drains to see if any coolant is coming out of there then you may need a heater core or one of the associated hoses, just be hoping the turbo coolant lines aren't leaking, they usually don't unless from a bad install. if it is a head gasket do a compression test to make sure they are all at somewhat equal levels just to try to rule it out
    Jun 20 2007
    Silicon Valley, CA
    I've been waiting to find a leak for the past few days but my commute to work & home barely lets it warm up. :(
    Registered Member Three Rings Charlie's Avatar
    Sep 16 2006
    West Haven CT
    I found my leak to be the T in the coolant reservoir, it was small but still needed me to fill the reservoir every day almost
    |Stage 2+ B5 S4|
    FOR SALE
    Mar 21 2008
    My leak was the AUX waterpump.. It was comeing from the back of the motor and only leaking when the cars front end was at an angle... the tank would be completely empty when i came out but the car would not leak on straight ground.. hoepfully give u some insight
    Jun 20 2007
    Silicon Valley, CA
    Thanks again. I've been checking the coolant tank for loss each day. This even after driving it to full operating temp over the weekend.
    Veteran Member Three Rings Auburnsky1287's Avatar
    Jan 06 2008
    Orlando
    Quote Originally Posted by lrg8683 View Post
    Same thing happened on mine too.
    2001 Audi S4
    Vast Tuned Stage 3
    Sep 16 2005
    Asheville, NC
    The aux water pump is a very common problem due to it's location.
    Linky link link...
    http://www.audizine.com/forum/showth...light=aux+pump
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Interesting. I'm losing coolant as well and don't notice any smoke. I'll check this out. Haven't noticed a puddle of coolant leaking on the bottom of my car though...
    Jun 20 2007
    Silicon Valley, CA
    Quote Originally Posted by drkenan View Post
    Linky link link...
    Maybe you missed it... I'm already trying to check for a leak from my Aux Water Pump (w/out removing the intake manifold). Still no luck finding evidence of one much less another puddle under my car.
    I know that I'm still loosing coolant though when I check the reservoir level.
    Senior Member Two Rings one4eyes's Avatar
    Jul 31 2007
    Bay Area, Cali
    Quote Originally Posted by jed3s4 View Post
    How and how hard would it be to change the O-rings in the coolant pipe?
    Thanks.....
    * OEM Performance *
    Dec 06 2007
    Calgary, AB, Canada
    It's not that bad, but a little bit of a pain in the arse because you've gotta get down below the big bundle of wiring that runs across the back of the engine. The hardest part is just getting your hand down in there.
    Dec 06 2007
    Calgary, AB, Canada
    Take a pic from underneath showing the coolant streaming down the side of the trans/engine.
    Nov 21 2011
    UK
    i have a similar issue in that the coolant level drops every 2-300 miles. I have replaced the rear coolant flange, the temp sensor seal and it still drops. Now white smoke, no pressurising of the header tank (other than normal) so i'm sure the HG is ok. I had a jubilee clip on the rubber t-piece pipe connected to the steel header going over the top of the engine so replaced this with the original Audi constant tension clamp.
    Can seem to find any coolant trails anywhere, perhaps i'm not looking in the right areas?
    Welcome any suggestions. 2004 1.8T BEX engine btw.
