Results 1 to 12 of 12
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Driveline Shock...
    So, the car is fully loaded with 4 people in it. I am at about 65mph and give it about half throttle, it builds about 2psi of boost in the meantime... at this point I decide to let off a bit and give it quarter throttle... as soon as I do this it feels as if a shock goes through the driveline..almost as if I tapped on the brakes when I really didnt...... whats going on here? I try it again but then its smooth... It almost feels as if the turbos are surging or something, like maybe the bypass valves are not opening up with a light throttle let-off. Its smooth on the other hand when I accellerate hard and let off completely.
    Any help will be appreciated.
    Condition of car: Vag shows no codes, no CEL, already pressure tested, bayley bpvalves with about 4000 miles on them, stock turbos, giac x with milltek turboback.
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Four Rings flips4's Avatar
    Oct 27 2006
    01.5&06 S4,04 MCS,08RangeRover, Ducati 848, YZ250F, and lots of TOOLS!
    Ocean Springs, MS
    Re: Driveline Shock...
    you might of hit somthing in the road. especially if you cant get it do happen again
    If it aint broke... Dont fix it!
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    I have the same issue starting to happen again. The first time it happened to me it ended up being a boost leak. My TBB was torn in half, but now I'm not sure why its happening unless have a leak elsewhere. I need to get a boost gauge so I can see if anything might be a problem.
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    tranny mounts??? idk lol
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Dec 06 2007
    Calgary, AB, Canada
    Sounds like the usual B5 drivetrain wear and tear to me. The DTS, stiffer than stock tranny and engine mounts, and the snub mount all help quite a bit to get rid of the play in the drivetrain, but at the end of the day, there will probably be a little bit just from wear and tear.
    Veteran Member Three Rings jeproks's Avatar
    Jul 14 2004
    Bahay Kubo
    Sounds like EGT sensor problem.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by jeproks View Post
    Are you serious right now? Do you think before you post?
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Jul 14 2004
    Bahay Kubo
    Quote Originally Posted by ///M3 TO S4 View Post
    Excuse me? Did you woke up on the wrong side of the bed?
    Feb 22 2007
    Earth
    I have been doubting the condition of my EGTs for quite some time... why do you think it might be the EGT sensors? I dont think its mount related myself. It feels as if there is a surge in the powerband, almost as if the turbos themselves were surging due to lack of recirculation. It only does it when letting off slightly.. (for example three quarter throttle to one quarter throttle) If I let off completely its actually smoother.
    Have you had this problem before and found out it was a rich condition caused by your egts?
    Jun 15 2007
    well egts will cause random missfires not on specific cylinders tho so you wont need to unless u wantto but i doubt that will fix your problem, what have you dont so far unispeed?
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jul 14 2004
    Bahay Kubo
    Yes, I experienced the exact same symptoms on my car before. No codes/CEL either and it turned out to be one of the EGT sensors that was causing it.
    Dec 06 2007
    Calgary, AB, Canada
    You can log the EGT's and we'll know if they are causing a rich condition.
    Have you pressure tested the car?
