Results 1 to 38 of 38
Thread: Boost on K03's?
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Boost on K03's?
    Bought an MBC and TCD from vast,trying to figure out what to run for boost on my k03's and to run it in parallel with the n75 or not.
    01.5,only stage 2,brand new k03's (>4k miles),GIAC X software
    TCD in parallel with N75 or standalone?
    What should i spike and hold at for boost with the MBC? Want safe but aggressive...
    Thanks.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Boost on K03's?
    Don't know..but how did you end up with brand new K03's?
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    good ol' certified pre-owned 100k mile warranty! haha blew the originals and got new ones for free
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: Boost on K03's?
    Quote Originally Posted by EuroSteez View Post
    Thats the exact reason why Audi isnt going for turbos anymore. They are still buying k03s!
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    hahaha,not like i blew em on purpose! just happens when you put GIAC software to them...anyways back on topic! WHAT BOOST can i run?!
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: Boost on K03's?
    Yeah, didn't mean it as your fault - just saying they don't have a great track record.
    So yeah on topic: 16-18PSI will be fine.
    Lots 'o Goodies
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    If you have GIAC software and its the newer version just use the MBC no N75 valve and you wont need a TCD with that software. As far as boost I have mine spike at 19 to 19.5 lbs depends on the day it fluctuates a little. Do a few pulls in 3rd and watch block 115 with vag com
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost on K03's?
    What elevation are you at?
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    elevation....hmm...i duno? in MA.
    yeah i thought i could run the MBC standalone,but a friend told me i have to keep the n75 or something would happen,i forget what he said.
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: Boost on K03's?
    You can run it in stand alone.
    You can run just the MBC with a TCD and you'll be fine. With a good tune, you can work the K03's pretty well.
    --Adam
    Have questions? E-mail me.
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    haha nope,they knew i was chipped. i didnt tell them,but when they called they said "we found a flashloader in your car,do you by chance have a chip?" i said "yeah,and?" and they didnt say anything about it so...i think they were trying to get something out of me. plus i had piggies with test pipes too...
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    If you need help let me know I live in MA also you are at sea level btw, but I would just run the MBC standalone get rid of the n75 valve. Also you dont need a TCD depending on what version of GIAC software you have, I run standalone with no TCD and have zero problems, car pulls real hard.
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    Re: Boost on K03's?
    Question: can I run a MBC with the APR 91/93 program...?
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    i think the install is pretty easy and self explanatory,TCD is the 2 wires on the MAP sensor on TB,and MBC is just as easy.
    i live right next to Wachusett mountain so i dont live at sea level,but i commute to providence everyday so thats sea level...
    not sure what GIAC i have,got it from Marc (10secs4) before he was banned.
    I'll run the TCD anyway,what harm can come from it ya know..
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Re: Boost on K03's?
    You can not run MBC with APR software. It goes into limp mode.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    Re: Boost on K03's?
    Well that sucks...but thanks!!!
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    is spiking at 20psi too much? one of you said 18,other said 19.5...why not go for 20? then maybe taper down to 18 or so...that ok?
    waiting for my god damn AWE vent gauge too. ordered it like a week ago with 3 day shipping and it hasnt gotten here nor have i heard from them with a tracking #
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    20 psi spike will be ok try not to push it more then that. As far as running apr software you can use it with a MBC but leave the N75 valve plugged in and you then need a TCD with apr also
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Boost on K03's?
    cool,thats what i'll do then with the MBC alone and the TCD in place.
    What happens when i switch programs with the flashloader?
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    the boost wont spike at 20 psi it will spike at whatever program you set it too, you wont need to touch the boost controller at all.
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    I have GIAC as well. I was running standalone(and TCD) but found that the boost was very unstable at part throttle. The car was spiking at 19 and sometimes holding other times it would taper to 15 by redline at full throttle. I hook my N75 back up to say the least. I left my N75 valve plugged in along with the passenger side vac line hooked up when in standalone would this have anything to do with it? Would completely removing the N75 have been better? Did I need to plug the open ends of the N75?
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    Remove the n75 completey and plug the pcv recirculation line with a bolt and a clamp
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    Does that mean I had a bad boost/vacuum leak then?
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    it should taper to around 15psi at redline it wont hold at 19psi so I wouldny say you have a boost leak that is normal
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    Ok thanks. I set it up the right way and lowered the boost so it was hitting 17ish and holding 15 and the car feels much stronger than when it was hitting 19psi.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost on K03's?
    19 psi is slightly outside of the efficiency range of K03's IMO, at the very upper limits at least.
    The N75 SHOULD be left plugged into the ambient air pressure line (pass side line) with the electrical connector plugged in.
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    Do I need to cap the 2 open ends on the N75? With it out I have noticed part throttle is much better?
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost on K03's?
    Nope, don't cap it off at all. If you are having problems, then you probably have some other issue that you are masking by capping off the ambient line and disconnecting the electrical connector.
    What were you boosting at before with the N75 in place? I would put the N75 back in (just the ambient line and electrical connector), and leave the MBC set to 17-18 psi. See how it runs.
    Jul 06 2005
    Re: Boost on K03's?
    This thread is full of stupid. Running an MBC only on K03's is just about the WORST thing you can do with them.
    Have fun with your next turbo swap.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    With just the N75 I was hitting 13-15psi(GIAC on Pump). I have the MBC set to 17psi right now by itself with no N75 in place. I think I am just going to run the N75 and thats all and let the GIAC software do its thing. Also Question if the S2 O2 sensors are not plugded in at all meaning at the firewall will this have an effect on the cars performance? I know if your just getting the old warm-up code its fine but I am getting open circut on both as well?
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost on K03's?
    It won't affect performance. It'll just give you a fault code.
    If it were my car, I'd run the MBC in parallel with the N75 to cap boost spikes but run the boost that the chip was designed for.
    Sep 14 2006
    14 GLI
    Re: Boost on K03's?
    ^ x2
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    All I can say is iv'e run a MBC for months with no n75 plugged in completely deleted and I have zero issues, as far as a boost spike if the boost controller will only let in 17psi then thats all its going to do. I dont know why so many of you have so many problems, but I have had zero and the car pulls real well.
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Boost on K03's?
    Oh and some of the fastest low 12 second k03 s4's run MBC only
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost on K03's?
    "MBC only" usually refers to MBC in standalone, which includes the ambient line on the N75 left plugged in as well as the electrical.
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    Jordan I'll plug her back in for ya tomorrow. I am seeing a fair bit of oil from the driveside Forge Splitter. I think my turbo is on the way out and could be causing the inconsistant boost. I may be calling you for some advice on turbo options.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost on K03's?
    Sounds good Ryan. That sucks, but at the same time it's frickin awesome, trust me
    Jan 14 2008
    00 S4
    Cranbrook BC
    Re: Boost on K03's?
    Haha ya I will need a clutch and turbos, fueling for now can wait.
