Results 1 to 12 of 12
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    any way to bleed a cluctch without power bleeder
    I dont have a power bleeder for brakes, my car is upon stands and i am car less till i figure it all out. i have a 3.0 so the tranny may be a little diff. where is the bleeder screw and what is the process of bleeding a clutch?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: any way to bleed a cluctch without power bleeder
    Why do you need to bleed your clutch? Did you just change your clutch or something that required removing teh tranny?
    I ran into this same problem changing my clutch. After MANY, MANY, MANY attempts of conventionally trying to pump the clutch pedal (in order to bleed it) it proved to be unsuccessful. LUCKILY I found someone locally who had a power bleeder, so in 30 seconds my clutch was bled! I then bought my own. Which I HIGHLY recommend you do.
    Anyways, here what you need to do:
    2 people are needed. Pump up clutch pedal a few times and then the second person opens up the bleeder while the the person in the car pushes down on the pedal and when it bottoms out you tell the guy under the car that it is at the bottom and he closes the bleeder.....Reapeat until all air is out.
    Bleeder is located on top of the bellhouse on the slave cylinder.
    Search for better and probbaly more clear instructions
    -Sami-
    Sep 07 2007
    Atlanta GA
    Iam changing my brakes, i was instructed to bleed my clutch to, i may just buy a power bleeder tonight...
    Feb 19 2007
    Charleston, SC
    dude buy the powe bleeder. I bled my whole brake system and clucth in about 15 minutes (longest time was jacking it up and removing all four wheels)
    -Sami-
    Veteran Member Three Rings darkstar's Avatar
    Dec 25 2004
    1998 silverado, 1986 c10
    Folsom, CA
    just buy a bleeder you will thank yourself later!!
    Sep 07 2007
    Atlanta GA
    just bought it, ibroke down
    Oct 29 2005
    10speed
    San Francisco, CA
    lol im lazy i dont take off the wheels
    - Clint
    Feb 19 2007
    Charleston, SC
    True....you really dont need to....I could have just reached in through the spokes! lol
    Come to think about it.....I dont know why I did....
    -Sami-
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    you could try gravity bleeding it, i do it on my jeep all the time.
    Registered Member Two Rings
    Sep 25 2007
    Santa Fe, New Mexico
    Where would you buy a power bleeder? (other than on line)
    2004 A4 Quattro 1.8T USP 6MT (white) XM, Ipod
    35% tint, AT Italia Spider wheels, BFG KDW 2, 235 40 18, K & N, RS4 Rear Sway bar, STaSIS Alcon rear brake upgrade.
    USP Club Member #80
    Sep 07 2007
    Atlanta GA
    motive 0100 amazon or ecstunig its cheaper on amazon
    Established Member Two Rings cuerna's Avatar
    Jun 23 2010
    Lubbock, Texas
    I need a little help
    i dont where is the clutch bleed screw, some can tell me please i want to bleed my brakes and clutch next week. I have an A4 B6 FWD 1.8T
    thanks
