Results 1 to 14 of 14
    Veteran Member Three Rings Auburnsky1287's Avatar
    Jan 06 2008
    Orlando
    Timing Belt Questions
    Well I've had my 2001.5 S4 for about 4 months now. Its at about 58k miles. The timing belt hasn't been done yet.
    So I'm just curious. I just spent 1200 on the car the other day including chip+ some maintenance stuff and I'll be tossing 220 down for some dv's. Can I wait on the timing belt? or is it imperative that it is done very soon!? I saw an s4 at the shop that snapped a timing belt and destroyed the motor... now I'm all nervous
    Also, how much does it typically cost from a shop, +labor do get it done?
    2001 Audi S4
    Vast Tuned Stage 3
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Re: Timing Belt Questions
    I think through a dealer it's in the $1100-1500 range. It probably would've been a wiser choice to do maintenance prior to modding the car, however, if you're that worried about it breaking.
    Dealer recommended TB service for 2.7/2.8 motors is 105k, I'm doing mine no later than 85k to be safe (as recommended by the Audi tech who works on modded audis), but probably sooner, seeing as I'm only at 61k right now.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    I did my 1st tb job at 100,000 miles. None of the parts I replaced felt any different than the new ones, honestly.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    it all depends on how lucky your feeling :)
    Im at 65k anbd i didnt do mine yet, ive been chipped for about 5k miles... I'll be doing mine over the summer.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I did mine at 80k and my tb looked good. Do it yourself. The Audi dealership here charges $150 and its a 8 hour job. The money saved on labor can be used for more performance parts :)
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    2000 s4
    Fairfield, CT
    either do it or wait for it to break and spend 3k for heads. ive seen people get away with 100k plus and some break at 60. i do mine and sell them at 60k. 1200 is cheaper than a a pair of heads. i did mine on my s4 at 65k, 122k and would hav done it at 175 again if i didnt sell it
    i heart my s4
    Veteran Member Four Rings SurferD's Avatar
    Apr 30 2007
    15 Forester XTT, 03-F150, 03-WRX, 71-240Z
    Orange, CT
    I have about 83k now and need to do it too.
    Who has the best kit for sale?
    Currently: 2017 Q7 Prestige 3.0 with APR tune.
    Formerly: 2007 S4 Avant 6MT; 2002 S4
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Doing the timing belt is VERY important. We recommend they be done between 60 and 75k miles for piece of mind. If your belt fails you'll have massive and catastrophic engine failure.
    Our 2.7T timing belt kit includes everything you need for the belt service.
    2.7T Timing Belt Kit
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by Auburnsky1287 View Post
    I'm guessing you and frimmel go to the same shop. Was that S4 Nogaro blue?
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    I did mine at 108 000kms which is about 68kmiles and looked like crap. It was cracked all around. I would'nt pas an other summer with it.
    Jan 06 2008
    Orlando
    Quote Originally Posted by Rapter View Post
    yes it was Nogaro blue, stage 3, with milltek exhaust... and other goodies
    I need to get a hold of the dude if he's parting out!
    In regards to the timing belt, I'd rather have a shop do it. I'm no super grease monkey but I know what it takes just getting to the damn thing. (Not the way it took like an hour to change out the one on my 2jz) I'd be much more comfortable letting a shop do it.
    2001 Audi S4
    Vast Tuned Stage 3
    May 01 2004
    2009 honda CRV
    Jersey
    Your a little late to the slaughter, but who knows you might get lucky.
    http://www.audizine.com/forum/showthread.php?t=202821
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    just did mine at 91k and everything was in great shape. as for cost, the book time is 5.5 hours so figure the labor rate off that and if you're replacing the belt, tensioners, waterpump, and pullies figure about 600 in parts through a shop(i did it at cost through my shop and i had just under 400 in parts alone)
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    I'm at 74,600 and am looking to have mine done this year. My TB is almost 8 years old and that is the main reason I am doing it, not because of the mileage. I have been chipped for almost 10k miles but msot of it has had the chip in stock mode. Only recently have I been leaving it in performance mode. I am going to have my plugs done at the same time too.
